Old 02-05-2010, 12:00 PM   #16
Integra's Avatar
you know my feeling's Bigedmond.
Old 02-05-2010, 12:14 PM   #17
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Yes i do. I think the quality of work he does is second to none. I just think some of the changes need a little more work. I would say, I wish he would have found the same anodizer for his chassis as the Losi. The losi doesn't wear out nearly as quick, since it seems much thicker. Again, petty issue.
Bigedmond is offline   Reply With Quote
Old 02-08-2010, 12:08 PM   #18
Grimlock212's Avatar
Originally Posted by losi_racer View Post
ONLY thing i added on my losi servo saver top,
http://www.amainhobbies.com/product_...um-8B-8T-10-20
It was mentioned on the Losi forums that the race roller now comes with an updated servo saver. Do you think they are including the aluminum one now?
Also does it come with an aluminum or steel flywheel? I assume aluminum.
Grimlock212
Losi 8ight 2.0: Clockwork Racing Engines JLR .21, Hitec 7955tg x2, Spektrum DX3S
Losi 8ight-T 2.0: Clockwork Racing Engines JLR .21, Hitec 7955tg x2, Spektrum DX3S
Losi Ten-T: 7/7/2, Kingpin tires, optional Losi Springs, Spektrum DX3S
Nor-Cal Hobbies: Union City, CA
Grimlock212 is offline   Reply With Quote
Old 02-08-2010, 12:37 PM   #19
losi_racer's Avatar
Trader Rating: 25 (100%+)
they went back to the 1.0 style, and no the top servo saver isnt included but its only 20$ and that area takes abuse so its worth it. and roller comes with alum flywheel. steel is only needed in blown out tracks imo
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 02-08-2010, 12:50 PM   #20
Neal at Clockwork Racing recommended the steel flywheel for the JLR mod engine I am getting. He told me I might have traction issues otherwise.
Grimlock212
Old 02-08-2010, 02:01 PM   #21
Integra's Avatar
get 1 to have on hand...if you feel the need for it...use it...ill be running one at the NC unless the track dictates otherwise.
Old 02-08-2010, 02:44 PM   #22
losi_racer's Avatar
nick wat c.springs do you run???
Old 02-08-2010, 02:54 PM   #23
Integra's Avatar
buggy ? ill probably start with my normal gold green and go from there...i have No clue what the traction's going to be like out there so it'll be a little learning curve for me to get used to im sure.
Old 02-08-2010, 02:56 PM   #24
losi_racer's Avatar
maybe thats why you run the steel, I run the green and black springs, clutch lasts x2 as long and i have great bottom end, but in truggy i run the gold green
Old 02-08-2010, 03:05 PM   #25
Trader Rating: 61 (100%+)
Originally Posted by pyromania View Post
The first batch of front towers were too thin and people kept breaking them. Losi updated their tower a long time ago.
The KHZ towers are much thicker the stock and weigh about the same if not less. They look so much nicer too.
upgraded towers in the losi box are great ...not much breakage ..cant see replacing something that works for a pretty piece of king headz
they are Not Needed.
+1 ...ive said it before and i will say it again the farther you stray from stock or stock options the more setups could change ...and you will constantly looking for how to set up an XYZ aftermarket part to match what has been proven to win ..just my .02
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 02-08-2010, 03:08 PM   #26
losi_racer's Avatar
i stick with losi on all aftermarket stuff EXCEPT the rear hubs on the truggy, wish losi was smarter on that
Old 02-08-2010, 03:14 PM   #27
yeh they coulda stuck 8x16's in there fo sho
LATER COOKIE
TEAM PROLINE-RACING
Old 02-08-2010, 04:26 PM   #28
My buggy is stock except for aluminum steering servo horn, aluminum adjustable toe-plates and two piece engine mount.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 02-08-2010, 05:36 PM   #29
losi_racer's Avatar
exactly what i have, i need the front hinge pin brace tho
Old 02-08-2010, 09:54 PM   #30
dishsoap's Avatar
I just installed the newer losi 12 degree aluminum caster blocks. I must say I like them. Buggy felt great coming out of corners on power.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
BCE speed Losi 8ight 2.0 3mm chassis xxxtcr Nitro Off-Road 355 12-17-2012 11:05 AM
Losi 8ight 2.0 or AE RC8? LowBoost Electric Off-Road 16 04-08-2009 07:02 AM
Losi 8ight 2.0 parts on 8ight-T TIX Nitro Off-Road 37 01-06-2009 12:57 PM
