Old 02-02-2010, 01:32 PM   #46
Trader Rating: 48 (100%+)
All of this talk of the Toro being soft on the bottom is a bunch of crap. If you run the right pipe/header (9901/41021) it has all the power your truggy will need. Frank, my Toro was well over 8 gallons (stock) on it and I still get a consistant 11 min a tank out of it, I got 12 min at Delta when I was there on Dec 5th. The problem that I have seen with all of the Toros I have tuned is too rich on the bottom and too lean up top. It likes a SLIGHTLY rich bottom, and since it revs to the moon, you need to keep an eye on the top. When optimally tuned, it should idle all day long with no issues.
My Toro still turns heads at the track. I regularly run down cars on straights with ease. Once you get it dialed in, I think you will really like that motor. Ask Phillip Atondo for help getting it tuned.
Up in the air...
Cyberacer is offline   Reply With Quote
Old 02-02-2010, 04:21 PM   #47
reggie l.'s Avatar
Originally Posted by Frank L View Post
You crack me up man.
....let me know how you like it, get some vid!
im glad i didnt get the plus 4 when i said i was because i think these team motors will be even better
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 02-02-2010, 04:27 PM   #48
You have to compare aples to aples, to compare two motors put them in an exact same buggy, with the exact same electronics, exact same clutch setup on the same track under identical conditions, and then only then you can properly compare them, they are both good mills, just diferent.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 02-02-2010, 04:35 PM   #49
houston's Avatar
Trader Rating: 91 (100%+)
not much change on the plus4 but definite noticeable changes on the toro
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 02-02-2010, 04:37 PM   #50
reggie l.'s Avatar
as in run times, or power, OR BOTH
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 02-03-2010, 06:58 AM   #51
kgombe's Avatar
subscribe
kgombe is offline   Reply With Quote
New Novarossi .21 Toro Nero 7Ports Xchange Offroad Nitro Engine Forum 263 06-30-2014 04:55 AM
Nova rossi Toro Nero...FMS r1harper Nitro Off-Road 85 01-21-2010 12:26 PM
OS Speed V-Spec II question Frank L Nitro Off-Road 32 05-20-2009 10:50 PM
Nova 367 or speed nover367 Nitro Off-Road 18 01-31-2009 07:55 PM
