Old 01-30-2010, 05:50 PM   #1
mazdamike's Avatar
Send a message via AIM to mazdamike
Default somthing faster than the pro .28 ideas??
i just bought a RC8 rtr after about 10 tanks i realized i need somthing faster mostly for bashing and racing around with friends. any suggestions on engine upgrades?? do any accept the pro start?
HPI Baja 5B-SSWC
FG marder
mikesgs430tt@aol.com email
mazdamike is offline   Reply With Quote
Old 01-30-2010, 06:06 PM   #2
Trader Rating: 21 (100%+)
if this is your first rc buggy I'd say run this engine to the ground while learning to tune and gain experience... then buy a quality mill, there are a number of bashing engines. Please DO NOT start a new thread for that... there already are plenty of them just look at the first few pages of this forum. For starters look into Jammin, GO Tech, Werks B5 and Nova engines. You can get all of them for around $200.
TopGearRC is offline   Reply With Quote
Old 01-30-2010, 06:50 PM   #3
mazdamike's Avatar
yea from what im reading people have nothing but good things to say about the B5.
HPI Baja 5B-SSWC
FG marder
Old 01-30-2010, 06:51 PM   #4
mazdamike's Avatar
Default jpx .21 or the B5 .21
would either of these accept pro start back plate u think?
HPI Baja 5B-SSWC
FG marder
Old 01-30-2010, 07:56 PM   #5
that .28 properly tuned can be fast, on the other hand no pull start motor will ever be as fast as a bump start, apples to apples. And with a bump start fast reliable motor you are looking at the same cost or more as your buggy RTR, plus you will need a starter box, and for the record a race motor ex. VZ-B speed will last very litle time as this motos are not designed for WOT runs.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 01-30-2010, 09:22 PM   #6
Eagle7's Avatar
Trader Rating: 25 (100%+)
change the pipe on that motor to a JP2 and you'll be amazed at the amount of power it already has. I spent alot of money trying to get rid of that engine and all I needed was a new pipe. And you can find a JP2 for about $30 on here.
MBX7T-Werks B5-2013. MBX7T Eco
MBX7r-Werks B6-2058 MBX7r Eco
TLR 22 2.0 & 22 2.0T
Werks Racing
Eagle7 is offline   Reply With Quote
Old 01-31-2010, 02:49 AM   #7
Trader Rating: 36 (100%+)
I agree. Try a tuned pipeset first. Most RTR style pipesets are designed for torque. Try a top end oriented tuned set and you're sure to be much more happy. Also, look into changing your clutch too. Run the snot outta the RTR mill, learn to tune on it.
NitroOB4You is offline   Reply With Quote
Old 01-31-2010, 06:36 AM   #8
mazdamike's Avatar
which clutch would be better. the alum shoes?
HPI Baja 5B-SSWC
FG marder
Old 01-31-2010, 06:38 AM   #9
mazdamike's Avatar
does anyone have any good links for the JP2 pipe for my pro .28?
HPI Baja 5B-SSWC
FG marder
Old 01-31-2010, 11:44 AM   #10
Eagle7's Avatar
FS: NIP Jammin JP2 HC pipe/manifold
Werks Racing
Old 02-04-2010, 06:29 PM   #11
mazdamike's Avatar
Talking
i just bought a near new mint JP2 for 29 bux and the 17t pinion . looking foward to the weather getting better
HPI Baja 5B-SSWC
FG marder
Old 02-04-2010, 08:38 PM   #12
If you want something that is insanely fast PM Maximo (that's his user name on Rctech). Also check out Youtube under Clockwork Racing.
Link: http://www.youtube.com/watch?v=Lr7vp8P9IqY
Jesussaves is offline   Reply With Quote
Old 02-04-2010, 08:41 PM   #13
smokinu's Avatar
Trader Rating: 60 (98%+)
os28zx
that thing will turn anything into a rocket.
send it to an engine modder and have them put even MORE power into it.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 02-04-2010, 09:03 PM   #14
WheelNut's Avatar
Send a message via MSN to WheelNut
Pretty much any racing engine will be faster, and there aren't any other engines that will take the RTR starter. Buy a starter box. You will reduce the weight of your car and get rid of the drag causing fail point that is the one way bearing.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 02-05-2010, 01:17 PM   #15
Madbrad's Avatar
Trader Rating: 29 (100%+)
If your willing to use a starter box the options for motors will more than double. Your going to be limited to mostly RTR type motor if you want to keep the roto start on there. No say that these are not good motors just a lot of other options out there too. Two of my choices would be the Werks B5 or the Jammin JPX.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
