Old 02-08-2010, 10:29 PM   #106
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Originally Posted by Marcus Falconie View Post
I run a Fusion Mod B3 in my buggy and a EB mod Extech in my truggy and yes they are fast but the thing I like is the motors just run better. I know they were built by Pros. I know Chris from fusion and he does a great job he told me that the mod is only part of what they do, they clean and lube your motor for break in. You dont have to worry there is metal shavings in your new motor.
http://www.reidrc.com/v-specos.htm
this is what the best motor mod guys do they just make a good motor better. I ran Rich Reid motors for a few years and they are nothing short of amazing. One day when I have the money I will get another Reid motor
Thats a cool link never saw that one
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 02-14-2010, 12:39 PM   #107
houston's Avatar
Trader Rating: 91 (100%+)
oh bouy
strolling through ebay , check this out
http://cgi.ebay.com/Quality-nitro-en...item4a9e94247d
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 02-14-2010, 12:52 PM   #108
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by houston View Post
oh bouy
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 02-14-2010, 01:09 PM   #109
houston's Avatar
Originally Posted by JAMMINKRAZY View Post
i mod therefore i am
proper modifications can produce engines that run excellent , improper modifications will F your engine up , there is plenty of the latter going around
Old 02-14-2010, 02:43 PM   #110
Very true!
-Koby Kubrin-
Old 02-14-2010, 08:36 PM   #111
22Racer's Avatar
Trader Rating: 67 (100%+)
I have rebuilt modded motors from reputable modders that do not know which way the air flows in the motor, It amazes me.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 02-14-2010, 09:03 PM   #112
houston's Avatar
Rex
If you are thinking of a certain guy that has an r and a b in his name , trust me there are reasons that he does some of the stuff he does to cranks that may not look like they work but they do certain things to atomize fuel
His stuff is very crazy but it works , too much power for me , I prefer a uaseable powerband
Old 02-15-2010, 06:57 AM   #113
Maximo's Avatar
fuel is atomized at the venturi (spraybar) ...any further contact inside the engine will actually separate the mixture...No amount of fancy cuts inside is going to increase atomization, in fact many of them are going to do the exact opposite....
Maximo is offline   Reply With Quote
Old 02-15-2010, 07:06 AM   #114
kgombe's Avatar
i used his engines and they do work.... very well... whatever he does he does it well...
kgombe is offline   Reply With Quote
Old 02-15-2010, 09:46 AM   #115
houston's Avatar
thats the first point and most important
what happens when the fuel/oil mix goes into the crankcase and bounces back and forth between the crank , the rod and the backplate ?
Old 02-15-2010, 10:12 AM   #116
Maximo's Avatar
it separates..... which is why you try to remove as much interference as possible.......you cannot re-atomize the mixture in the crankcase !
Old 02-15-2010, 11:11 AM   #117
neobart's Avatar
I run modded engines not because I have to have the fastest thing on the track(OK I can't deny it's kinda cool), but because they just run much better, well the ones from the guy who makes mine anyway.
What I get is an engine that idles better, has smother throttle response and will keep up with the higher dollar speeds, and RB's without me having to lean it within an inch of it's life. Notice how many drivers had flameouts in the just held worlds warm up race. Pro drivers could care less if their engine wears out after 2 gallons. Those 12min runtimes(or whatever they claim) can not be translated to the rest of us mortal racers. If I get an engine that is smooth, idles well and allows me to pit at 8-9 minutes comfortably, I'm more than happy.
But you better choose the guy to mod your engines wisely. Some modded sleeves look like they've been through the internals of a chipping machine. Other takes a skilled eye to spot what's been done, but once you drive it you can tell.
neobart is offline   Reply With Quote
Old 02-15-2010, 11:36 AM   #118
houston's Avatar
What I get is an engine that idles better, has smother throttle response and will keep up with the higher dollar speeds, and RB's with me having to lean it within an inch of it's life. Notice how many drivers had flameouts in the just held worlds warm up race. Pro drivers could care less if their engine wears out after 2 gallons. Those 12min runtimes(or whatever they claim) can not be translated to the rest of us mortal racers. If I get an engine that is smooth, idles well and allows me to pit at 8-9 minutes comfortably, I'm more than happy.
nice post bart
Old 02-15-2010, 04:16 PM   #119
pitpop's Avatar
...if I thought the engine would be better, there is no reason why I would not say to go ahead and modify an engine... there is no bias. The high end engines don't need to be modified, that is my opinion.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 02-15-2010, 04:17 PM   #120
pitpop's Avatar
oh bouy
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
To EB mod or not to EB mod BIGTACO Onroad Nitro Engine Zone 10 09-22-2006 06:13 PM
To brush or not to brush??? EHHH??? dmlk Rookie Zone 34 11-29-2005 01:20 PM
