Axe Rossi Mamba
Axe Rossi Mamba
I just picked up one of these motors for my 8ight. Has anyone run this motor and have any idea on what pipes would work best for it.
yes, I got it from A Main
Someone must of run this motor by now.
I received my Mamba today. It sure is a nice looking engine. The quality looks very good and the piston fit is very tight like a nova engine. Anyone run this mill yet? Is the included R6 plug a good plug for it? What pipes does it like?
Registered User
Hey mate. I have one of these motors with only 2ltrs run through it. The pipe I am using is a ttr efra 2039 kit. It has a ripper of a torque range low to mid I am just trying to get a little more top. The performance though is excellent. I run this motor in a ttr st1 and it is just what I was hoping for. The clutch bell is a 13t. I know a guy who also runs this motor with a efra 2047 and in his opinion is a great match also. The tracks I run on is fairly tight you need more torque maybe if it was more open I would use the ttr efra 2035. This should be a good starting point. I have been running the supplied axe 6 plug and its fine, still in. I have an lrp 6 platnium plug to use next. The nova 6 is also meant to be good for this motor. Cheers Scott.
Thanks, I will definately try a different pipe maybe something like a 086 or a JP2 from jammin.
The JP-3 works exceptional with the Mamba and Cobra.
And the Axe magic pipe 2022 bit with the std manifold as it comes with the angled manifold to fit the LSK/Black Magic
Cool, I will have to add the JP3 to my list.
Does anyone have the factory settings for the Mamba's high and low needles. Mine keeps getting flooded and is hard to start when I try to start it for break-in. I have only managed to get it running for about 2 to 3 seconds.
can anyone that is running this motor tell me what a good plug is for it.... i have a motor on the way, and would like to know what plug is good..... I have ran odonnell 77 in the past on my 21bf with good luck, just wondering if that would be a good plug or the 99 or should i go with the rossi plugs?
also for a track with low traction 1 long straight and medium to low tight stuff and good gas milage PIPE... i have jp2, 086, 063, 053?
The supplied glowplug works well. It is a Rossi #6. I will have to try the MC59 sometime. I would recommend the jammin JP3 pipe.
i got this motor, now i am ready for break-in... but one thing i would like to know is... do you have to add the shim for 30%... my motor can with a shim... and when i take it apart and look at it, it already has 2 shims... so if i add the other one, that would be 3 shims ? is this right for 30% ???
thanks
thanks
