What tape do you use?
What tape do you use, on the inside of your buggy/truggy body? How does it hold up?
I seen some Gorrila Tape, and was thinking about trying some of it.
Thanks,
-NuthinFancy91
What tape are you reffering to? The one used so the exhaust doesnt ruin the paint job?
Edit: Forgot to post a link http://www.amainhobbies.com/index.ph...at-Shield-Tape
All it is, is aluminum heat sheild tape
Yeah Jeff, what ever people use to keep paint from rubbing off as quickly.
-Bo
I prefer High Temp silicone for protecting the inside's of my body's vs the heat tape.....ive seen that stuff melt before and peel the paint off with it.
shoe goo or a high temp silicone works the best then put heat tap over that where the pipes at to help keep some of the heat off the body
Ive seen ShoGoo peel off paint which is why i prefer the silicone.
I do stage production and I have always used gaffers tape. It has a matt finish, it is cloth, it leaves no adhesive when removed, stays on even after washing, available in many colors and has many uses.
http://www.productionadvantageonline.com/Tape/
None. I just put stickers over damaged paint
Whats the point reflecting the heat back inside the car with aluminum tape.
I did a test on painted body clippings between shoe goo and the Permatex high temp silicone nick is talking about. The shoe goo did peal the paint off while the silicone did not. Just spread it like butter over fiber sheetrock tape. and you'll be fine.
