Old 01-28-2010, 12:48 PM   #1
Mino's Avatar
Default Plase Help me to correct my truggy handling
Hi, this is my first thread here, but im not completly new at RC since I have had a E-Revo for a year now, but now I got a Hot Bodies D8-T to start racing, and the other day I went to the track to practice and I noticed my truggy have a tail happy attitude, every corner i have to be VERY gentle on the throttle in order to keep the truck from spinning out, part is because my track is very loose right know but is very annoying how can I correct this?
My set up is,
Diff: F: 7000 center: 7000 rear: 4000
Shocks: F: 40wt R: 50wt
using Pro-Line Caliver tires
All the rest is were the manual said, box stock set up.
Thanks in andavance
Mino is offline   Reply With Quote
Old 01-28-2010, 01:15 PM   #2
Charles Godwin's Avatar
Increase the rear diff oil something like 7,7,5 or 7,7,7. Softer clutch springs, Change the oil weights around, 50wt front, 40wt rear. Softer rear rollbar? Longer rear wheelbase. Could try a softer centre diff oil. More rear toe. Lots of things to change possibly.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 01-28-2010, 01:28 PM   #3
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
+1 Any of those... + a couple more you can try.
Raise the inner end of the upper suspension link.
Lengthen the upper suspension link.
Increase (MAYBE!!) rear camber.
Change to better tires.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-28-2010, 01:59 PM   #4
My set up is,
Thanks in andavance
If your truck is rear lose, there i s a few things in your current setup that will cause that..
1st your diff fluid setup will cause your truck to push hard (tail happy)
change to 7000 front, 10000 center and 2000 rear, yes 2000 this will allow the inner tire to spoll and keep you on track whille the front 7000 will pull you out and the 10000 center keeps the power from unloading in the rear.
2nd your shock oils are not right, reverse them 50 in the front and 40 in the rear, softer damping in the rear allows for more traction without unloading the tires.
Make sure your toe in and out is right and yorur camber is the same side to side front and rear.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 01-28-2010, 02:03 PM   #5
pickle311's Avatar
Trader Rating: 31 (100%+)
The first thing I always ask myself is "are the tires doing their job". Tires are roughly 80% of your setup, everything else is fine tuning. Calibers are good tires from what I hear. What compound are they, M2 or M3? What was the surface temp of the track? You said it's more dusty than normal. In that case, I will use whatever tire I have that works best for that condition. If that's not enough, I'll decrease the rear camber by 1 to 2 degrees. If that's not enough then I start changing the roll center. Lengthening the camber rods in the rear will slow the rear end down some and make it feel like there's a little more side bite.
pickle311 is offline   Reply With Quote
Old 01-28-2010, 02:10 PM   #6
You could add more front droop also to allow more weight transfer to the rear on power . You could also on the rear suspension raise the front mounting block of the lower arms to make the arms lean back towards the rear off the car (think it's a anti squat adjustment, sorry i get confused with all the technical wording but know what that certain change does lol). Again more weight transfer
Old 01-28-2010, 02:13 PM   #7
Mino's Avatar
thanks for all the replys, lot of good info! I will start by changing the shock fluid and and if its not enough I will change de diff oil before proceding.
Something that I just noticed is that when I place it on my starter box the rear tires are getting lower than the fronts, and its not the droop screws since I have them all the way out, could this be part of the problem, or its normal?
Heres a pic to explain what I mean:
Old 01-28-2010, 02:19 PM   #8
Generally normal to have more rear droop than the front. Even by looking at the picture your starter box might not be letting the front arms 'sag' whilst it's on there. To get a measurement of droop get some calipers, raise the car up with tyres not touching the ground. From the centre of the top mounting shock screw measure from there to the centre of the lower mounting screw. You then got your droop measurement.
Old 01-28-2010, 02:32 PM   #9
Tony Newland's Avatar
Trader Rating: 50 (100%+)
My set up is,
Thanks in andavance
Instead of making a new thread, stop by the D8T thread.... all the talk there is specifically about the truggy and there's lots of guys that have alot of good information. Duplicate threads are anoying
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 01-28-2010, 05:19 PM   #10
Mino's Avatar
Oh ok, i'm sorry
