Old 02-03-2010, 05:32 PM   #61
Trader Rating: 16 (100%+)
Just got the X2 yesterday. I really like this car. Much lighter than the x1 and the drivetrain is much smoother. I can't wait to drive it.
supertool28 is offline   Reply With Quote
Old 02-03-2010, 06:10 PM   #62
Daniel....older, heavier, and not as smooth. Were you talking about the x1 or it's driver? After trying out your x1 last wk I'm looking forward to seeing the difference with your x2. Wonder if those spiral gears will fit my z-car.
drdsanders is offline   Reply With Quote
Old 02-03-2010, 06:53 PM   #63
fast11970's Avatar
Originally Posted by looper View Post
from others who have run their products i have heard that the aluminum is alot softer than they claim and that i should avoid the chassis a little bit more than i would an STD.
Here is what I know, new Chassis, one five minute practice at the Nitro Pit, Handeling got weird, started inspecting every thing, chassis was a frikkin taco, bent at several angels, used my worn out stock chassis..no issues at the Nitro challege '08..If you wanna upgrade I reccomend KH or F products..you get what you pay for..
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 02-03-2010, 06:56 PM   #64
fast11970's Avatar
Too Big..Gears will not fit the case, the stock gears are bullet proof on either model, the X2 jammin gears are spiral cut, so you have to change the pinion as well, not just the ring, The internals are the same as the X1, they work fine, just do your maintenace.
MBX6
Old 02-03-2010, 07:32 PM   #65
WOW, what a rip. It's going to suck when I whoop you after a long 8 months off from racing. Never Fear I will post the results of the next race we have together and of course the results when we meet up at the Psycho Nitro. Your Z-car will be put in it's place. As a second rate car, in second place to my Jammin.
Old 02-03-2010, 07:51 PM   #66
jmaxey51's Avatar
make sure to shim the diffs tight, a little on the notchy side or the ring and pinion will strip. i have seen it happen alot to alot of different people. also on the internal diff put two shims on all the gear (the ones that make an X). i didnt do that on one of my diffs because the buggy directions dont say to and i stripped the internals. so i looked in the X2 truggy manual and it said put two on each so i did that.
jmaxey51 is offline   Reply With Quote
Old 02-03-2010, 08:41 PM   #67
thanks for the info.
Old 02-05-2010, 05:49 PM   #68
Another rainny weekend is the south. That kills running the X2 this weekend. Maybe next week.
Old 02-05-2010, 07:37 PM   #69
jmaxey51's Avatar
hey supertool28 i just saw that your from savannah, and are you going to run the GCS?
Old 02-06-2010, 06:14 AM   #70
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Hey guys try'n to restore my old x1... Will an x2 body fit the X1?...Thank you!
SCUBA STEVE is offline   Reply With Quote
Old 02-06-2010, 01:12 PM   #71
rallyebmx's Avatar
Trader Rating: 21 (100%+)
They are the same bodies. The rear body post hole is moved a bit and the engine cut out is also moved. Thats all though
cpaurl
rallyebmx is offline   Reply With Quote
Old 02-06-2010, 04:46 PM   #72
I'll run some of them, not sure how many yet. Only plans for sure are to run The Psycho nitro.
Old 02-06-2010, 09:08 PM   #73
jmaxey51's Avatar
the X2 body just has sharpie marks to where the wholes are supposed to be for the x2 but just ignore the marks and cut where out where they were originally. also with the x1 you do not have to cut the front part off to make it fit.
Old 02-07-2010, 03:35 AM   #74
JUD
JUD's Avatar
As long as the opening for the cooling head is not cut out of the new x2 body it will fit. If its cut out them the hole will be off.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 02-07-2010, 05:10 AM   #75
Thanks guys!
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Let's talk drivetrain wear/slop and best buggy to minimize this Cannondale1974 Nitro Off-Road 23 09-05-2008 07:24 AM
Who has the baddest Buggy on the block??? Arty_Harvy Nitro Off-Road 9 08-25-2008 08:45 PM
