Old 01-26-2010, 08:51 AM   #1
Angry need help with jammin x1 crt
Does any one know where i can get the small gear combo for the jammin X1 Crt truggy. I'm trying to install BCE PJX chassis and the flywheel i have is hitting the servo tray.
joshuaczech is offline   Reply With Quote
Old 01-26-2010, 10:02 AM   #2
Torian4000's Avatar
Trader Rating: 49 (100%+)
Call Nitro House 800-928-0304 or visit www.nitrohouse.com They would be your best hope for anything Jammin.
Torian4000 is offline   Reply With Quote
Old 01-26-2010, 10:02 AM   #3
plus2ss's Avatar
Sounds like you mean your spur gear is hitting the servo tray, not the flywheel. Im pretty sure the Hot Bodies Lightning Stadium Pro spur, ring and pinions are all you need for the small gear conversion. Our you could just get the gears from an X2crt.
plus2ss is offline   Reply With Quote
Old 01-26-2010, 01:19 PM   #4
mechanic77's Avatar
plus2ss is right, you can use Hot Bodies Lightning Stadium Pro parts, but the cheapest/easiest route is to get complete diffs from the D8/D8t off of ebay. You can use either D8 or D8t front rear diffs (they are the same) but you will want the D8t center diff (it has the 50t spur you want). The only part that must come from the HB Lightning Stadium Pro is the pinion gears, the pinions from the D8/D8t have a smaller shank and won't work with the Jammin center driveshafts. If you need part #s, pm me and I will try and get them for you.
Thanks, Andy
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 01-26-2010, 02:58 PM   #5
Thanks, Andy
+1 I do the same with mine .
nothin special is offline   Reply With Quote
need help choosing a truggy ibmenace Nitro Off-Road 66 09-12-2010 02:00 AM
Jammin X1-CRT Truggy kevin107 R/C Items: For Sale/Trade 8 06-13-2007 03:14 AM
