Old 01-25-2010, 12:42 PM   #1
Default Appropriate HB D8 Upgrades
Well, I have researched for a little while now and cannot find any definite answers. Can someone tell me what parts are necessary for a D8? 112mm rear shocks, what else? Anything particularly important? Thanks!
C.Harper is offline   Reply With Quote
Old 01-25-2010, 12:52 PM   #2
Default ...
If I were you I would run it stock first. You might like it like that. I personally have titanium turnbuckles taller tower with longer shocks and a bce chassis.
2010 Sponsors....BCE Speed, Xtreme Power Systems,
Battlefield R/C, Reino's Ragu Sauce
Garrett McKamie is offline   Reply With Quote
Old 01-25-2010, 01:02 PM   #3
rcgeezer's Avatar
You should check out the "New Hot Bodies Buggy" thread on this page. It's loaded with info and suggested upgrades.
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 01-25-2010, 01:38 PM   #4
blktransam's Avatar
Trader Rating: 59 (100%+)
persoanlly the only thing I have "up graded" on mine is the rear cvd's to the WCE version...everything else stock, I dont even use the longer shocks..
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 01-25-2010, 02:12 PM   #5
I've been racing my D8 for almost a year. Only upgrades I have on it are aluminum steering servo horn and a beefed up plastic throttle servo horn. Also, I drilled and tapped the front a-arm rear holder. If I was gonna do any other upgrades(which I don't plan on it any time soon), I would do the rear shocks. The D8 is plenty fast stock. The upgrades I made were for durability.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 01-25-2010, 02:17 PM   #6
keep your 97 rear shocks, go with the yellow springs, 1.2 pistons and 600 wt oil,
the alluminium servo horns are great,
as for the titanium parts, when my bank acct can back up my ambititios I'll be changing to titanium turn buckles and hinge pins. you could also lighten the drive train.
other than that the D8's a great car. I love mine.
rc_racer1 is offline   Reply With Quote
Old 01-25-2010, 02:22 PM   #7
fatdaddy's Avatar
heres the link: New Hot Bodies Buggy!!???????
durability upgrades - aluminum servo horn, M2C captured outer hinge pins, M2C captured front inner hinge pins, and CVD boots.
Performance upgrades (in order of necessity imo) - lightened drivetrain (crown gears, spur gear, outdrives, alu wheel hubs), lightened chassis, 112mm shocks, all the other lightweight bits (steering posts, brake arms, suspension balls, titanium stuff, etc...)
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 01-25-2010, 02:49 PM   #8
RX313BT's Avatar
Trader Rating: 14 (100%+)
As most have said, for duarability upgrade the steering servo horn to aluminium, i didnt change the throttle/brake as i never had an issue, and i had to upgrade my front driveshafts due to breakages, never had a real issue with the rears, upgraded the front centre driveshaft to a dogbone due to standard drive shaft wear, other than that enjoy the car i also still used the standard short rear shocks. When you want to upgrade for performance, light chassis, alloy suspension balls, carbon shock towers and titanium screws and turnbuckles
Adelaide RC Team Driver
WWW.ADELAIDERC.COM.AU
Xray XB9 & XT8.5, Proline, Nitro-X Fuel.
Xray XB4, Nosram, Proline.
TLR22,TLR22T Model Flight.
RX313BT is offline   Reply With Quote
Old 01-25-2010, 03:32 PM   #9
CHogle's Avatar
Send a message via MSN to CHogle
i run the car bone stock and i love it. the only thing that i do that would be concidered a hop up is the aluminum steering servo horn. i also grease the crap out of the cvd's and put GMK supply CVD condoms on all the CVD's. this will make the cvd's last longer than if they were not greased.
if you put a good setup on the car, the car can win right out the box. look on the hotbodies buggy form for setups.
C.HOGLE
Serpent America, Novarossi, O'Donnnell fuel, PT Racing Oils, SMC, H-bomb Designs, Stick it 1 racing, Motor Savor Filters, Fastraxx Hobbies
CHogle is offline   Reply With Quote
Old 01-26-2010, 07:07 PM   #10
ok, thank you all for the responses!
