Old 01-24-2010, 12:35 PM   #1
Default crank pin size v-spec?
does any one know the size of the crank pin new on a vspec? trying to decide wether or not to replace just the rod or rod and crank both
jammin28 is offline   Reply With Quote
Old 01-24-2010, 01:09 PM   #2
offr0aden's Avatar
The factory is .196 and the tolerance is -.003
If your crank pin is at .193 with a new rod you might get a couple gallons before the rod bushing wears and the crank is totally done.
For Example: with the pin at bottom dead center - your 12 and 6 o'clock measures .194 and the 9 and 3 measure at .192 or less - you need to replace your crank.
- Team -
"High Speed and Clean"
offr0aden is offline   Reply With Quote
Old 01-24-2010, 05:26 PM   #3
hambone's Avatar
I was told by my engine man that novas are .196, but OS is .195.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 01-24-2010, 08:10 PM   #4
22Racer's Avatar
Trader Rating: 67 (100%+)
Most crankpins are pretty close to .196, Rb's are around .198, some .28's are much bigger.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 02-14-2010, 01:50 PM   #5
MontanaMaxx's Avatar
is this sae measurement or metric? i measured my crank pin and got 4.95 mm is this acceptable?
MontanaMaxx is offline   Reply With Quote
Old 02-14-2010, 01:55 PM   #6
Trey7's Avatar
4.95 mm equals 0.1948.
Hobby Pro USA, Beta Tires, VP-PRO-USA, Werks Racing, Team Associated, Savox
Trey7 is offline   Reply With Quote
Old 02-14-2010, 02:05 PM   #7
malcnz's Avatar
also watch if youre crankpin is out of round and can make the crank useless..vspec cranks dont last that well in my experiance ..but the speed cranks last and last due to the coating on them.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 02-14-2010, 02:10 PM   #8
thanks it measured 4.95 all the way around and there didnt seem to be any visable signs of wear on the crank pin so looks as if i will be fine to use this crank
Old 03-28-2010, 07:22 PM   #9
houston's Avatar
Trader Rating: 91 (100%+)
there made with metric measurements i figure its a good idea to measure in metrics
new 4.98 to 4.995
throw away at any out of round or coning more than .04mm or if any measurement is less than 4.92mm . last rerod at 4.92mm will be good for about 1-2gallons and the crank will be garbage!!
novarossi engine based opinions
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Rw modding and engine rebuilding 22Racer Offroad Nitro Engine Forum 455 11-28-2016 07:38 PM
BIG RC SELL UP ON ROAD OFF ROAD ELECTRIC NITRO drusty Australia For Sale/Trade 38 02-08-2010 09:37 PM
====V-Spec parts lot for sale=== WYLDTHING R/C Items: For Sale/Trade 12 06-29-2009 03:39 PM
