Old 01-27-2010, 07:51 PM   #31
Originally Posted by didrace View Post
Guys when you use the rpm guage to set camber do you put the car on the droop blocks? Or is better to have it at its right height?
Also i do own an mracing station which i left it in cyprus now and i am i london but i want to set my front toes..Is there any accurate way i can do it without the station?
They are very expensive..
before i got the hudy system i cut me four 4"x 4"x 3/16" lexan blocks,(to put in palce of the wheels) and a good smooth flat 20" x 20" plywood board,a compase,and a rpm camber gauge, so i could set it up and i could do most everything that the hudy system will do it just takes longer. for setting the toe you can measure the front and rear of the wheel and for every 1/16th it will be very close to 1degree. so if you measure the front side of the wheel and it is say 8 1/8" and the rear side was 8" you would have 2 degree's total toe out and would be 1 degree per wheel. hope this helps
axle is offline   Reply With Quote
Old 01-27-2010, 09:55 PM   #32
Frank L's Avatar
Trader Rating: 148 (100%+)
The hudy set up station just makes life easy and I am a huge fan of the easy button. Besides why would you want to do it the hard way it just does not make any sense.
Old 01-28-2010, 08:15 AM   #33
mudboger07's Avatar
lol so true, I love the easy button....... Before I got the set up station I swore I had the set up correct, Id always double check everything to make sure, then after setting it up with the hudy, I was quite a few degrees off...Click the easy button.......
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Hudy set-up Station #108255 xrcbuggy Nitro On-Road 29 04-23-2011 01:27 AM
HUDY SET-UP STATION GOING CHEAP freestyles Australia For Sale/Trade 9 07-27-2008 11:22 PM
HUDY set up station #10-8250 wikedgmc R/C Items: For Sale/Trade 15 11-29-2007 10:26 AM
Hudy Set up Station hype Australia For Sale/Trade 16 06-30-2007 08:30 PM
Hudy Set-Up Station, CE Pitbull, and Losi Tools for Sale MUDVAYNE R/C Items: For Sale/Trade 18 01-04-2007 07:37 AM
