Old 01-23-2010, 02:42 AM   #1
mini696's Avatar
Default Oil changes with regards to air temperature.
By how much (in general) do you increase oil weights by as the temperature rises?
D8, GO 5Port
Ve8, RX8 1900, Promatch 5100 4S
SC10, Hobbywing EzRun
mini696 is offline   Reply With Quote
Old 01-23-2010, 02:49 AM   #2
MontanaMaxx's Avatar
well the viscosity of the oil is not supposed to change with tempature i dont really believe that but i havent really noticed a need to change on tempature i ran same at 30degrees as i did 90degrees seemed fine to me
MontanaMaxx is offline   Reply With Quote
Old 01-23-2010, 11:17 AM   #3
Peter Martin's Avatar
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Towards the bottom of the page is a chart on temp effects on shock oil.
Peter Martin is offline   Reply With Quote
Old 01-23-2010, 11:44 AM   #4
stipres's Avatar
Trader Rating: 70 (100%+)
Hey Peter, good info! Out here in Cali we get pretty good swings in temperatures btwn afternoon and evening, and vice-versa. Usually a 10 to 15 degree difference, personally I can definately feel a difference if I dont change my shock oils. To answer your question, I would change only 50cs or 2.5wt, depending on how extreme the weather change. (Example: 500cs during cooler and then 550 when warms up or 40wt to 42.5wt.)
Same goes for long Mains. anything over 20 minutes or so I would bump up the oils as well, depending on how important the race is
Pres Ilog
AKA Products, Team Losi, Track Star Racing, Tekno RC, Hitec RCD, LRP, Schelle Racing, Imagine It Graphics, EKD, VP/PowerMaster fuels
stipres is offline   Reply With Quote
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
