Old 01-22-2010, 11:39 AM   #16
mattozx6rr's Avatar
Trader Rating: 15 (100%+)
Maximo,
Its a mugen flywheel.
Wingracer,
Grinding on my BCE chassis is not an option I am willing to explore.
1 X MBX6T plus 21-4c
Twisted Bones R/C apparel
mattozx6rr is offline   Reply With Quote
Old 01-22-2010, 04:10 PM   #17
wingracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by mattozx6rr View Post
Wingracer,
You just have to open up the holes a bit. You probably only need a couple mm. Once the mount is on you will never notice.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-24-2010, 05:37 PM   #18
you need to get a different flywheel. i have different flywheels just for this reason. you may also need a shorter pilot nut so the clutchbell will line up with the spur gear.
troy8481 is offline   Reply With Quote
Tags
bigblock motor mounts, mbx5t, motor mounts
