Old 01-21-2010, 08:23 PM   #1
Trader Rating: 17 (100%+)
Default OS 18tm and and OS 21tm help
Hello,
I have these two engines which are to be used on a two revos, I bought the whole clutch setup with a 40mm flywheel. The nut that holds the flywheel in place will not turn after one turn, the size of the nut is 1/4 with 28 thread i believe. Any help
maxx05 is offline   Reply With Quote
Old 01-21-2010, 08:27 PM   #2
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
Originally Posted by maxx05 View Post
Hello,
I have these two engines which are to be used on a two revos, I bought the whole clutch setup with a 40mm flywheel. The nut that holds the flywheel in place will turn after one turn, the size of the nut is 1/4 with 28 thread i believe. Any help
Hey man, I can try. Did the clutch nut come with the flywheel? It should take a standard traxxas clutch nut.
What exactly do you mean turn after one turn? Do you mean it won't tighten down all the way?
boomgagem is offline   Reply With Quote
Old 01-21-2010, 08:33 PM   #3
im using the traxxas nut thats for sg shafts. After one turn trying to tighten it, it will not turn anymore.
Old 01-21-2010, 08:34 PM   #4
boomgagem's Avatar
You need the TRA5244 clutch nut, I may have an extra I can send you, lemme check
Old 01-21-2010, 08:40 PM   #5
boomgagem's Avatar
I checked, I don't have one, but yeah, you need that clutch nut, the same one for the 3.3. The TM engines don't have the SG style shaft
Old 01-21-2010, 08:42 PM   #6
ok i will give that a shot tomorrow
Old 01-21-2010, 08:50 PM   #7
would the the 2.5 pull start work on both of them
Old 01-21-2010, 08:51 PM   #8
boomgagem's Avatar
Yeah it will bolt right on there
Middle East RC (Qatar RC Club/Abu Dhabi RC) CRahoD Manila Racers 1788 02-09-2014 12:26 PM
to go big block is it worth it daniel15fl Monster Trucks 24 07-01-2009 09:47 PM
REVO PLATINUM REPLACEMENT MOTOR? charly71 Monster Trucks 24 06-02-2009 06:10 PM
