XRay XT8 Question
It's not worth it. I run an 08 Spec XT8 as well and when I looked into it...there was no kit available so each part had to be ordered individually. The cost was almost the price of the 09 Spec! I should check again, maybe they released a kit...but I'm not aware of one.
The recommendations (from the XRay Forums) were to choose only the 09 parts you knew you needed. So if the 08 Spec Parts aren't giving you problems....I wouldn't bother with the upgrade. I am still contemplating a chassis upgrade though since the 09 is longer, but that means new Center Shafts and a body....which adds up quickly.
It costs to much to upgrade the truck you have the easiest thing to do is sell it and buy the 09 spec
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
I don't think the full upgrade is worth it. But some things are!
I run the 07/08 spec with 808 shocks (you have to use 808 rear shock shafts in front, and XT8 rear shafts in the rear if you do that) but you can just buy the 09 spec shocks now. THAT is a good upgrade!
I have the front upper camber link mod on mine (hard to explain... basically you use a camber link like the rear on the front. Not hard to do) That helps with steering. The 09 spec has that already. THAT also is a good upgrade, and relatively cheap.
The 09 spec has lightened CVDs and the outdrives are different too. Not needed in my opinion, unless you are trying to be ultra-competitive. I doubt the average driver will notice the difference.
The chassis is longer on the new truck, so the center CVDs are different... and it uses the 808 motor mount instead of the older style one. Those are the parts worth upgrading IMHO.
The shock towers, servo tray, and center diff top plate are carbon fiber on the new truck. I actually personally PREFER aluminum, even with the extra weight. If I bought the new truck I'd put the stuff from my old one on it.
p.s. the captured hingepin stuff you asked me about before in PM do NOT come with the new truck. You still have to buy that stuff separately if you want it.
I run an 808 King Headz Motor Mount on my 08 Spec. I just drilled some new holes in the chassis ;-)
I also got mine as a roller with Jammin Big Bores already installed. VERY nice upgrade...
DOMIT....tell me more about this camber link upgrade? Pics maybe?
Hard to see in the pic, but here it sits...
I think it would be pretty easy to do with a dremel and some patience with a piece of aluminum rod... these were made by a guy that does machining though.
The money you will spend to upgrade the chassis, center cvd's, big bores, new radio tray and a new steering link that you have to use with the new chassis you will be spending over half of what a new 09 spec costs so sell you're truck put that money with the money you were gonna spend for the upgrade parts and you can buy a whole new truck and not have a old truck with with a new chassis and shocks
By changing the shock shaft like that , wont that cause the shaft to break the bladder when you bottom out ?
I'm pretty sure that drama isn't needed if you just buy the XT8 shock kit. Mine was done prior to the new truck, prior to big bores being available.
I also run an odd spring setup- front shocks on the inside hole, Jammin GREY springs for the buggy big bore rears on the front. Jammin BLUE truggy big bore rear springs. Rear is middle hole on the lower mount.
I've got my truck set up very lazy and easy to drive. I need it that way, I don't have the skills to deal with an aggressive setup.
So, I've decided to keep my 08 Spec, upgrrade the shocks and front/rear suspension to the e-clip delete setup....then learn to drive the WHEELS OFF THIS THING! My question is, without buying the +5mm wheel adapters, what offset wheels should I run (it's been a while) standard or 1/2 offset.
Note that changing wheels on half offsets is more hassle, and SOME wheel wrenches don't work- either not long enough, or the diameter on some is too big to go into the hole.
