Old 01-20-2010, 01:50 AM   #1
Default LiPo Receiver Pack Questions
Hi
I just ordered a 2300mAh 7.4V receiver LiPo to run in my Losi 8ight and have a few questions:
1. What else do I need to run it on a standard receiver? I already have a charger with a balancer so I think I need a regulator. Do you need to run a balancer thing whilst it's in the car or just when charging?
2. What amperage should I charge it at? I've heard you divide the mAh by 1000, so that would mean about 2 amps, is that right?
Cheers
Ben
teamshaw is offline   Reply With Quote
Old 01-20-2010, 05:18 AM   #2
Most lipo packs can only be charged at a 1C rate max, which for a 2300MAH would be 2.3 amps.Unless you are running a spektrum RX you will need a regulator to be safe.There are a few different regulators on the market, depending on what servos you run you will need to adjust. If your running high torque,high speed servos you will need atleast a 5 amp regulator, if not you can probably get away with a 3 amp. one thing to remember is to ALWAYS unplug your regulator from the battery when your not using it. Even in between heats if your a racer, they constantly draw off of the lipo even if your switch is off. Hope this helps
Sholler is offline   Reply With Quote
Old 01-20-2010, 05:27 AM   #3
gkn0315's Avatar
Trader Rating: 126 (100%+)
[QUOTE=Sholler;6880048]Most lipo packs can only be charged at a 1C rate max, which for a 2300MAH would be 2.3 amps.Unless you are running a spektrum RX you will need a regulator to be safe.There are a few different regulators on the market, depending on what servos you run you will need to adjust. If your running high torque,high speed servos you will need atleast a 5 amp regulator, if not you can probably get away with a 3 amp. one thing to remember is to ALWAYS unplug your regulator from the battery when your not using it. Even in between heats if your a racer, they constantly draw off of the lipo even if your switch is off. Hope this helps[/QUOT
+1
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 01-20-2010, 12:43 PM   #4
Thanks for the great info guys.
I have a Spektrum SR3000 receiver so does that mean I don't need the regulator? Will the extra voltage harm the servos or is the receiver smart enough to handle that?
Cheers
Ben
Old 01-20-2010, 12:50 PM   #5
Cheers
Ben
The receiver can handle upto 9.6v,but unless you have high voltage servos,you will need a regulator.The lifepo receiver packs are good as you don't need a regulator or hv servos,but don't think anyone makes them to fit the Losi box.
dodger is offline   Reply With Quote
Old 01-20-2010, 05:02 PM   #6
blade954's Avatar
Trader Rating: 23 (100%+)
We run the HT brand of regulator and have found them great they even come with a little heat sink to aid in cooling so we have never had a issue with over heating, our package is now 18 months old and still going strong only replaced a 9351 steering servo due to gears breaking in a truggy.
http://www.amainhobbies.com/product_...or-with-Switch
blade954 is offline   Reply With Quote
Old 01-24-2010, 08:37 PM   #7
aray's Avatar
[QUOTE=gkn0315;6880066]
+1
I just got a lipo and reg, trying to learn a bit... even if the regulator is on the opposite side of the switch from the lipo, it still will draw through the switch if it's turned off?
right now I have:
6v -> switch -> receiver -> servos
charge lead
Will this work:
lipo -> switch -> regulator -> receiver -> servos
charge lead
If I wire it this way, is there still some danger in the regulator discharging the lipo through the switch?
aray is offline   Reply With Quote
Old 01-24-2010, 09:31 PM   #8
That I am not sure of, because I have never tried that method.The only reason I stressed that you unplug the lipo between heats is once the lipo is drained beyond a certain point, they are dead for good.I learned that lesson the hard way, luckily it was only a $17 dollar pack.Maybe someone else has ran that setup and might chime in for us, but personally I would still unplug it, nothing ticks me off more then running in warmup before the heat and something go wrong with my truggy..
Old 01-24-2010, 09:53 PM   #9
COBRARACING's Avatar
recievers and servo electronics have a tolerence of 9v its the motor that cannot handle the 7.4v .max voltage a none hV servo can handle is 6.6volt max
Lifep04 rx packs can be run dead flat not like lipos to a certain point and no regulator is needed
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-24-2010, 10:07 PM   #10
houston's Avatar
Trader Rating: 91 (100%+)
[QUOTE=aray;6902463]
right now I have:
charge lead
Will this work:
charge lead
thats how you do it
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 01-25-2010, 01:12 AM   #11
CanyonCarverR1's Avatar
[QUOTE=houston;6902847]
Originally Posted by aray View Post
thats how you do it
+1
CanyonCarverR1 is offline   Reply With Quote
Old 01-25-2010, 08:03 AM   #12
right now I have:
charge lead
Will this work:
charge lead
That's what I been doing for 1 year now, your OK if install the regulator directly on the receiver.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 01-25-2010, 09:04 AM   #13
aray's Avatar
thats how you do it
Thanks all for the answer and confirmation.
Old 04-05-2010, 05:34 PM   #14
1lowtaco's Avatar
this thread has answered half of my questions . Here are some more: Do I need to run a lipo cut-off too? My regulator is adjustable, what should I set it for?? The default is 5.1. Should I turn it up to 6v?
1lowtaco is offline   Reply With Quote
Old 04-06-2010, 12:22 PM   #15
1lowtaco's Avatar
Anybody???
Lipo Reciever Pack CREWMAN Nitro On-Road 7 12-30-2008 06:48 PM
Lipo receiver pack/regulator question thecman26 Nitro Off-Road 16 05-06-2008 01:56 PM
Lipo Receiver pack...need some info pumpkinfish Nitro Off-Road 40 01-16-2008 08:19 AM
