Old 04-06-2010, 12:28 PM   #16
Trader Rating: 21 (100%+)
6 is the safe way to go. I wouldn't set it anything under 6v. You don't need a seperate voltage cut off most regulators will cut off when the batt reaches below 6v.
TopGearRC is offline   Reply With Quote
Old 04-06-2010, 01:57 PM   #17
Lilja's Avatar
Im running Reedy Lipos and Reedy's voltageregulator (5 amp) and Ive noticed that it does generate a fair bit of heat. Which is why its probably a good idea to unplug it when youre not using it, since as someone else said youll drain your battery below a point where youll damage the battery if you try to charge it again (may even risk an explosion).
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 04-06-2010, 03:10 PM   #18
Send a message via ICQ to cow9527 Send a message via MSN to cow9527 Send a message via Skype™ to cow9527
if use LiFe will be better, without the regulator
Hobao Hyper 9 GL--star
Futaba 3PKS|BLS 351|BLS 451|
JConcepts|Pro-Line|VP PRO|ABEC35|AKA
RB B10|RB B11
cow9527 is offline   Reply With Quote
Lipo Reciever Pack CREWMAN Nitro On-Road 7 12-30-2008 06:48 PM
Lipo receiver pack/regulator question thecman26 Nitro Off-Road 16 05-06-2008 01:56 PM
Lipo Receiver pack...need some info pumpkinfish Nitro Off-Road 40 01-16-2008 08:19 AM
