Old 01-19-2010, 09:25 PM   #16
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Marcus Falconie View Post
I spent a hour pulling the pipe for the new track and I could have swore it was hard PVC the same thing we use at ET and SRS but what do i know. I have never seen Leech Line please post a picture. I thought a leech line was just the line that goes from your septic tank to your plumbing and that was THICK BLACK PVC able to withstand being under ground.
thats what leech line is marcus, i believe we use pvc for the outline
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-19-2010, 09:30 PM   #17
Jaz240's Avatar
Trader Rating: 52 (100%+)
All the straight sections are hard PVC. The curves are a more flexible pipe. I've spent hours on it marshalling and racing as have hundreds of others. It's a combination of both
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-19-2010, 11:30 PM   #18
MontanaMaxx's Avatar
you can find it at lowses or home deopt its drain tile non perferated pipe and its somewhat flexable as its not the hard pvc
MontanaMaxx is offline   Reply With Quote
Old 01-20-2010, 05:32 AM   #19
rdeppen's Avatar
You can't buy it at Home Depot. They only sell the cheap thin wall Black drain pipe.
Color non-perforated pipe (like the Pit uses) has to be special ordered from a drainage supply company like ADS.
rdeppen is offline   Reply With Quote
Old 01-20-2010, 05:35 AM   #20
MadRussian's Avatar
Thank you, thats what I have said 3 times in this thread, he is not asking about the black pipe, everybody know that can be obtained no problem, he was asking about the white or colored pipe
It can also be ordered from any of teh links I posted
MadRussian is offline   Reply With Quote
Old 01-20-2010, 06:22 AM   #21
NuthinFancy91's Avatar
There you go Dion...
Johnson Racing Team #94
Blue Groove R/C Apparel
Rccna Racing Team
Team Losi
NuthinFancy91 is offline   Reply With Quote
Old 01-22-2010, 07:34 AM   #22
gmanrc's Avatar
look at the links that are posed at the top of the thread and thats what it looks like. they ues the same stuff at my local track.
gmanrc is offline   Reply With Quote
Old 01-22-2010, 09:28 AM   #23
bgbelden's Avatar
Bo you ain't even right.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 01-22-2010, 09:53 AM   #24
Default pipe
There can be other piping options found at a plumbing supply warehouse or irrigation supply in your area. HD supply might be an option. You can also check out thebluebook.com which is the yellow pages for contractors.
If you are looking for a hard pipe at a lower cost check out SDR 35 sewer pipe. It's also a hard pipe similar to Schedule 40 pvd but the wall thickness is less and tends to be a little for giving.
As for flexible pipe you want corrugated single wall drainage pipe. Here is a link of a company that makes it in white http://www.spipipe.com/swp.htm.
Let me know if this helps or you need more info
Bfig is offline   Reply With Quote
Old 01-22-2010, 09:59 AM   #25
Kalgard Racing's Avatar
I even emailed Joey Christiansen and that is what he called it...."Leech Line".
The Pit may used different types of pipe, but when I was there in the fall it was Flexible.
Email Joey, he will help you.....
Kalgard Racing is offline   Reply With Quote
Old 01-22-2010, 10:03 AM   #26
Marcus Falconie's Avatar
that stuff looks good. I wonder how strong it is. If you want to know what the stuff is just go to the Nitro Pit thread in the race section and ask Todd Jonas aka Carkingaz and he will tell you.
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 01-22-2010, 01:39 PM   #27
This is what they use, this is from Todd the owner of the Pit it is Polyethylene Solid Drainage pipe http://redirectingat.com/?id=42X1295...alogId%3D10053
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
