Old 01-18-2010, 06:55 PM   #1
Trader Rating: 15 (100%+)
Default charging lipo rx pack
Allright I switched my latemodel to lipo rx pack. I know you aren't supposed to charge with the regulator hooked up. My question is this I have the switch with 3 sets of wires. One going to the rx that's where I put the regulator. The other side has a plug that goes to the batt and one to go out of rx box for charging pack. If I have the switch off would I hurt the regulator if I charged the batt using the the plug that goes out of the rx box from the switch? I ask because I hate to open rx box and unplug stuff to charge the batt.
CrazyFast1 is offline   Reply With Quote
Old 01-18-2010, 07:41 PM   #2
Galeleo's Avatar
It is extremely important that you disconnect your lipo battery at the end of the day when you know you are not going to use your car. If you don't, you will run the risk of running the battery to an extremely low voltage and as a result you may not be able to charge the battery or worse it could be damaged to the to point that it will puff or burn up on the next charge.
Your radio gear will draw a small amount of voltage even though it is turned off. Its this voltage drain that could damage the battery. All it takes is leaving the battery connected over night!
I learned this the hard way! Learn from my mistake, open your box and physically disconnect your battery when done.
Also it is a bad bad bad idea to charge your lipo in your vehicle. You cannot monitor the charge and if the pack starts to puff, you wont see it. If the battery catches fire you run the risk of burning up your vehicle or worse, your whole house.
Always remove lipos from your vehicle when done, and store them in a container that is fire resistant. I always charge mine in a steel container with a lid near by and a fire extinguisher and NEVER in the house.
Lipos are safe but if they aren't charged or handled/stored properly, they can be a hazard.
Just some food for thought
Galeleo is offline   Reply With Quote
Lipo Rx Pack Runtime phm14 Nitro Off-Road 12 12-14-2009 07:50 AM
LiPO rx pack? madweazl Nitro Off-Road 6 09-06-2009 12:03 PM
losi 2000 lipo rx how long to charge full J.Whiting Nitro Off-Road 11 11-18-2008 07:00 PM
Losi Lipo Rx Pack xrayrc Nitro Off-Road 15 03-09-2008 11:24 PM
