Old 01-18-2010, 03:42 PM   #1
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
Default Opinions..
What happened to this mill?
boomgagem is offline   Reply With Quote
Old 01-18-2010, 03:55 PM   #2
shane oc's Avatar
did u try to take the backplate of when piston was at BDC ?
*****TEAM TERRIBLES******
Answer-RC ------- maxamps
Torco Race Fuel-------BCG Industries
Fastlane Graphix-------Clockwork racing engines
Caster Racing
shane oc is offline   Reply With Quote
Old 01-18-2010, 04:46 PM   #3
boomgagem's Avatar
I don't know, but that was one of the things I suggested.
I'm posting this for a friend, The engine has about 1 gallons on it. Never over 220, run on 30% nitro juice.
Just wondering if anything can be determined from the pics
Old 01-18-2010, 04:54 PM   #4
j_blaze14's Avatar
Trader Rating: 34 (100%+)
blew out the bottom of the pioston, happens to all motors at any time, ususlly only 1 side goes though. manufacturing flaw really, send it back. 1.5 gallons and it looks like that?, remind me never to run nitro juice, yuk. i've seen motors 5 gallons old that didn't look that bad, what temp gun? she looks like she's been over 300.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 01-18-2010, 05:04 PM   #5
Trader Rating: 21 (100%+)
sh!t happens!
TopGearRC is offline   Reply With Quote
Old 01-18-2010, 05:05 PM   #6
MontanaMaxx's Avatar
Looks to me like is a traxxas 3.3 and thats your problem i had nothing but problems with them. and that looks as it ran a little lean and got hot
I installed a brand new rod and piston in one and it didnt last 1 tank of fuel and the inside of piston around the wrist pin broke just like that one is
Switched to an os motor and havent had an issue
MontanaMaxx is offline   Reply With Quote
Old 01-18-2010, 05:08 PM   #7
jpz_67's Avatar
Trader Rating: 56 (100%+)
Do you have a pic of the top of the piston? Would like to see it.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 01-18-2010, 05:24 PM   #8
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Interesting. Here are the things I can see:
Starting with the head... there is some pitting... not much, but a little bit. That could be detonation, (not shimmed properly, or running too lean) or it could have either ingested something or the coil could have come out of the glow plug. It is hard to tell after it has been cleaned up like that. It would be interesting to see the top of the piston too.
There is also a bit of scoring on the piston skirt. (I'm not talking about the broken parts, I mean the vertical "scratches" in the skirt that show distinctly in the carbon deposits.) Again this indicates that SOMETHING went through there. Obviously that could possibly be parts of the piston itself, given the damage... for that matter, so could the pitting on the head.
Given the deposits on the broken parts it is also obvious that it was run that way (with bits broken off) for a while. Otherwise the broken parts would simply look like metal.
The piston has a single groove (which acts like a ring) and is very rough in appearance- not a very well finished casting. I suspect this isn't exactly a top-quality engine.
It also doesn't look like what I remember my engines to look like when I ran Nitro Juice- the deposits were much more distinctly red in color, not dark brown approaching black.
Based on the darker carbon coloration on the piston skirt, the signs of pitting on the cylinder head, and the damage to the piston pin area... I would suspect it was ran a bit too lean (despite what was said about never being over 220 degrees- temperature truly is not the only factor.) The skirt doesn't look to be broken by pulling the backplate- unless it was reinstalled and ran after it was broken. It looks like a failure in use.
I'd suspect the cause is a combination of being too lean (and hence not enough lubricant) and a poor quality piston casting, and MAYBE over-revving it.
Again, that is just my thought on this... there are MUCH more experienced folks on here who may disagree.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-18-2010, 07:13 PM   #9
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Saved me some typing DOMIT!
Thanks, .
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 01-19-2010, 06:45 AM   #10
quadracer111's Avatar
IMO it looks like it threw a bearing...
Trust me, this engine was in GOOD hands. And Nitro Juice is made by Mike B himself, suppose to be awesome fuel.
quadracer111 is offline   Reply With Quote
Old 01-19-2010, 07:22 AM   #11
DOMIT's Avatar
Hmmm... VERY good point! I've seen a broken piston from a sloppy rear bearing before... piston hit the backplate and pretty much shattered.
But the yucky dark brown/black deposits look like it was run too hot.
I know many, MANY local racers, both sportsman and pro, running Nitro Juice, and I know Mike Battaile personally. He makes it, and he runs it. I've never seen anything like that (color of deposits on the piston skirt.)
I ran it for over a year, and never had a single problem... the ONLY reason I'm running another type of fuel now is that all of my "crew" is running O'Donnell. If one of us runs out, one of the other guys always has some handy, no retuning needed for different fuel. Nitro Juice is good stuff!
Old 01-19-2010, 07:33 AM   #12
losiracer78's Avatar
J_blaze i have been running Nitro Juice for over a year in 3 or 4 motors now and have never seen anything like that from nitro juice. That motor looks like its been well over 300 more then once for sure. Its not the fuel that made it look like that i can tell you that.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 01-19-2010, 07:58 AM   #13
Snook Man's Avatar
Being the mill is a 3.3, the piston skit does not extend down into the crankcase at BDC far enough for the back plate to interfere.
Snook Man is offline   Reply With Quote
Old 01-19-2010, 08:08 AM   #14
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Its obviously been very hot... carbon built up on the BOTTOM of the piston is never a good thing once its that hot all bets are off on the piston remaining in one piece. Looks like its seen alot of RPMs
1 1/2 gallons? Not buying that a bit.... thats a ton of color on the rod for that short of a life. I have engines that I put 6 gallons on that dont look anything like these parts
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 01-19-2010, 05:14 PM   #15
Every piston I have seen has the brown colour on the piston skirt...
I still say it had a bad rear bearing.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 09:16 PM
Prototype ESC's - ROAR, Legal, Fair, Sportsmanship, Opinions? kn7671 Electric On-Road 637 10-07-2009 11:15 PM
Opinions on King Motor Baja 5 Buggy (HPI 5B clone) BAD_S197 Oval, Larger Scales and More 12 06-21-2009 09:42 PM
HARD CASED LIPOS, opinions, concerns, thoughts? what are the choices? poorbie:( Australian Racing 106 06-10-2008 02:27 AM
