Old 01-18-2010, 03:24 PM   #1
Default PLZ HELP!! probly stupid question...
I just got a new engine so im trying to take the fly wheel off my old one and put it on my new one but I cant get it off?! How do I take the fly wheel off?
crockpot7 is offline   Reply With Quote
Old 01-18-2010, 03:31 PM   #2
use a vice or large pair of vice grips to hold flywheel, put a wrench on the large nut on the crank and turn
Average Joe's RC
HBTRAV is offline   Reply With Quote
Old 01-18-2010, 03:32 PM   #3
BTW you will need to gently knock the flywheel from the back to get it of the collet
Average Joe's RC
Old 01-18-2010, 03:39 PM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Or you can use a flywheel puller instead of "knocking it off." Much easier and less chance of damaging things.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-18-2010, 03:43 PM   #5
what is a fly wheel puller?
Old 01-18-2010, 03:55 PM   #6
Would anyone mind posting pics or a video of how to get the flywheel off? Or know of a link that could help?
Thanks for the advice guys.
Old 01-18-2010, 04:11 PM   #7
DOMIT's Avatar
This is a flywheel puller.
http://www.amainhobbies.com/product_...lywheel-Puller
Old 01-18-2010, 04:14 PM   #8
revo61's Avatar
Trader Rating: 18 (95%+)
Open back of engine and use this: tool This will lock the crank. Now u should be able to get the nut off. Then get either a battery terminal puller or this tool to pull off flywheel.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 01-18-2010, 04:16 PM   #9
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
just be carful when doing you should buy two things a puller and a wrench
Here you go
Puller
http://www.carolinasrc.com/Webstore/...idproduct=1020
http://www.carolinasrc.com/Webstore/...dproduct=11545
Wrench
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 01-18-2010, 04:34 PM   #10
looks like the stem with the handle on it pushes against the crank while the hooks pull on the flywheel. No thanks.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 01-18-2010, 04:34 PM   #11
MontanaMaxx's Avatar
I like to use chanel lock pliers with rubber hose not to mar flywheel and a deep socket to loosen nut so you dont damage clutch pins if you pop nut loose and bind wrench on the pin it can damage your pin or flywheel then take the plastic handle and give a good tap on the back of the flywheel to pop it off the collet this works without special tools though if you got the cash it seems alot easier with them gismos show above
MontanaMaxx is offline   Reply With Quote
Old 01-18-2010, 04:43 PM   #12
DOMIT's Avatar
So Dreaux, what do YOU suggest?
Old 01-18-2010, 04:49 PM   #13
captain america's Avatar
I've used mine countless times, and it never once marred or damaged anything on my engines, plus it makes even stubborn flywheels as easy to remove as pie.
captain america is offline   Reply With Quote
Old 01-18-2010, 04:55 PM   #14
with a puller applying even pressure it wouldnt take much to pop it off and most flywheels are aluminum and a crank is steel some hardened so no worry there and a guy could put a piece of nylon to protect the crank if worreid
Old 01-18-2010, 05:13 PM   #15
Trader Rating: 21 (100%+)
+1
TopGearRC is offline   Reply With Quote
