Old 01-19-2010, 04:54 AM   #16
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
remove the clutchbell then remove the clutch shoe. you will able to see the big nut in the center. Use adjustable lock plier or monkey plier to hold the flywheel tightly then turn the nut. After the nut is out, use a big allen key to softly hit the flywheel with oppesite way on the flywheel so that it will out evenly..Hope you understand what I said
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 01-19-2010, 05:45 AM   #17
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by MontanaMaxx View Post
with a puller applying even pressure it wouldnt take much to pop it off and most flywheels are aluminum and a crank is steel some hardened so no worry there and a guy could put a piece of nylon to protect the crank if worreid
Or put an old bolt (don't use the one you plan to put back in) in the end of the crank. But honestly, I've never damaged one with this tool.
Beating on the flywheel (with the crank held against a solid surface) DOES work... but you take more chance of damaging the crank that way than with a puller! AND you take more chance of damaging the flywheel... pins hit the surface and get jammed through the flywheel...
Use the puller. It is easier, faster, and less chance of damage.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-19-2010, 09:38 AM   #18
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Originally Posted by xjqkz View Post
+1
+2 pressure on the crank? even pull pops right off cannot get any easier
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 01-19-2010, 07:34 PM   #19
revo61's Avatar
Trader Rating: 18 (95%+)
I use a battery terminal puller myself.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 01-19-2010, 07:49 PM   #20
slotkarter77's Avatar
Trader Rating: 24 (100%+)
http://www.skygeek.com/ats-at508k.html
cannon plug pliers are great. i get them from a local aircraft tool supply.
these are also nice for building shocks.
Nick Edgington
Sponsors: Proline, Fantom, MIP, BOOM rc, Venom RC, Ogio International
slotkarter77 is offline   Reply With Quote
