I hate a Losi clutch. >
Old 01-17-2010, 06:30 PM
Suspended
Trader Rating: 5 (88%+)
Default I hate a Losi clutch.
Can someone help me with any tips and tricks they know to help get the 4 screws out of the 8 2.0 flywheel that hold the clutches on. The heads are stripped out there has to be someway of getting them out.
carlam is offline
Old 01-17-2010, 06:31 PM
smokinu's Avatar
Trader Rating: 82 (99%+)
get a cutting disk on a dremal, and flat head the heads of the screws...
a small blade hacksaw can do the same thing.
smokinu is offline
Old 01-17-2010, 06:43 PM
tc5 man's Avatar
or go to www.answer-rcusa.com they have the losi eight clutch, shoe pins that have a slot on them so its not so, easy to strip them out.
i had to use my dremel a couple of times to, get the clutch shoe pin out and im about to try them answer clutch shoe pins out . also you can be, easy on the clutch shoe screw and they still strip lol.
tc5 man is offline
Old 01-17-2010, 06:48 PM
Don't threadlock them in the first place. They'll never come out easy. As for getting them out, you'll probably have to cut them with a dremel and use vice grips to twist them out from the shaft of the pin. I've done that in the past. With the pins, I usually strip the head, then strip the slot that I cut in the head with the dremel, then I have to destroy the pin to save the flywheel.
Semple is offline
Old 01-17-2010, 06:50 PM
tc5 man's Avatar
i dont use threadlock on them i know better lol.
tc5 man is offline
Old 01-17-2010, 06:59 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
get better tools. i use hudy, hell even when i went to proline tools i stopped stripping the heads. they dont need much torque, once they are screwed in thats it. they wont screw anymore, people try to give it the last little turn and thats what strips them
losi_racer is offline
Old 01-17-2010, 07:04 PM
houston's Avatar
Trader Rating: 96 (100%+)
Get the ascendancy system !!!
It is high quality and easy to use
houston is offline
Old 01-17-2010, 07:07 PM
Take a dremel and grind a slight point into the front of the pin. This will help a lot with installation, and seems to help with removing the pins as well.
And like losi_racer said, use high quality tools. A good hex driver will help prevent rounding out the screw while installing the pin.
071crazy is offline
Old 01-17-2010, 07:08 PM
tc5 man's Avatar
how long does the clutch shoes, they make last? its a nice clutch
tc5 man is offline
Or you could just go 3 shoe like I did when I run the 2.0's
RAlmeida is offline
Old 01-17-2010, 07:10 PM
tc5 man's Avatar
yea but i like the 4 shoe clutch a lot better, for the extra surface and punch when i need it. i have tried a 3 shoe clutch, out before though.
tc5 man is offline
Old 01-17-2010, 07:20 PM
houston's Avatar
i personally haven't gotten that far with the clutch sets but the aluminum is not 7075 or 6061 but a rather special alloy
i dont do this usually but i must say i will endorse this product and i haven't even used it in my car !!!! that is not like me to do that
i have great confidence in doing this and believe you guys will have great results when using this clutch system
houston is offline
Old 01-17-2010, 07:22 PM
Frank L's Avatar
Trader Rating: 148 (100%+)
I like the losi clutch system 4 shoes so its balanced and tons of options plus you dont need a special tool to take the shoes out. I loctite mine and they only strip once in awhile only when the hex driver is worn. Get a new hex driver.I have been using hudy, they work well, the proline sucked, RD logics was not bad either or I just purchased a few shepard racing toold and they seem to be top notch so far.
Frank L is offline
Old 01-17-2010, 07:37 PM
pballer2777's Avatar
Trader Rating: 28 (100%+)
also make sure the drive is all the way down in the pin. there were many times i thought the driver was in the hex and when i went to turn the pin i striped the pin.
pballer2777 is offline
Old 01-17-2010, 07:42 PM
tc5 man's Avatar
yea i make sure the hex driver is all the way in the clutch pin also, but i havnt
made a point on the screw ethier, plus i use duratrax hex drivers lol. im gone to get better ones.
tc5 man is offline
