Old 01-16-2010, 09:59 AM   #1
Default i found out my rear wheel drive problem but how do i fix it
ok my dad looked at my car, took the metal plate on the bottom off and found the problem. there are 2 gears that spin the rear wheels. they are not connecting to each other! we wondered why but then my dad found lots of pieces of one of the gears on the plate. is that the problem or is it something else
rccarsrock is offline   Reply With Quote
Old 01-16-2010, 10:04 AM   #2
smb17's Avatar
Send a message via AIM to smb17
What car?
smb17 is offline   Reply With Quote
Old 01-16-2010, 10:10 AM   #3
dandrat's Avatar
your not explaining what car you have , but I would take a shot in the dark here and say those pieces are ether part of those gears( which should be obvious because the gears would look damaged) or another gear connecting the 2 that is eatin away. look at your owners manual to find the answer and if you dont have that check the manufacturers website for the instructions.
dandrat is offline   Reply With Quote
Old 01-16-2010, 10:10 AM   #4
it does not really matter but its a tornado s30 offroad buggy
Old 01-16-2010, 10:10 AM   #5
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
check all the bearings in the diff. both side bearings and the pinion bearings.. replace as needed. re-check gear mess. replace diff case, ring and pinion and bearings as needed to get proper gear mesh. jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 01-16-2010, 10:12 AM   #6
what car are you talking about we need details
rccarsarecool is offline   Reply With Quote
Old 01-16-2010, 10:23 AM   #7
fstrnu's Avatar
is it your spur gear that is damaged? your gears should fit together quite close. you should be able to hold one gear still and just SLIGHTLY rock the other gear. if this gap widens too much you will tear the teeth off of one gear or both. If your motor mounts have loosened a little it can let the motor rock enought to tear the teeth off your spur.
fstrnu is offline   Reply With Quote
Old 01-16-2010, 12:58 PM   #8
MontanaMaxx's Avatar
sounds like the diff gears are tore up need to do as previously stated check and replace gears and bearings that are bad and shim for proper mesh
MontanaMaxx is offline   Reply With Quote
Old 01-17-2010, 08:09 AM   #9
wow this is a major issue i just found out that all the teeth are gone!
no its not the spur gear its the one in the rear axel
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
i found out my front wheels will not turn rccarsarecool Nitro Off-Road 8 01-18-2010 10:20 AM
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
