Old 01-14-2010, 07:47 PM   #1
Default Car battery powered starter box
Can I power my starter box from my car battery or is it too powerful for my box?
Rhan
Inertia is offline   Reply With Quote
Old 01-14-2010, 07:49 PM   #2
jmaxey51's Avatar
most starter boxes come with an adapter to be able to hook it up to your car batter so yes you can if you would like.
jmaxey51 is offline   Reply With Quote
Old 01-15-2010, 08:21 PM   #3
MontanaMaxx's Avatar
just look up your starter box and the wireing options and most are set up to take 12 volt hobby battery thats the same as a car battery jsut need adapter for them
MontanaMaxx is offline   Reply With Quote
Old 01-16-2010, 04:13 AM   #4
j_blaze14's Avatar
Trader Rating: 34 (100%+)
be sure to make the connections safe, you don't want to short something from a $50 starter box and damage your many thousand $ car. i recomend a 4 cell lipo, very powerful and a 2200 will last a month before it needs charge.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 01-16-2010, 04:34 AM   #5
Toh WL's Avatar
usually most starter box can fit in Lead Acid battery 12V. that u can get from any electrical shops. basically they work with car battery. the same goes to your DC-DC charger..
when u feel there is not much torque, just remove the batt & charge it. as for lipo it's risky cause u need to look at the cut off voltage. hence most starter motor they supply with tamiya connector. u can plug in 2 x 7.2 NiMH stick pack as added alternative.
Toh WL is offline   Reply With Quote
Old 01-16-2010, 04:38 AM   #6
wallot's Avatar
nothing wrong with a car battery. it is just a battery that has high capacity and can handle high currents. it is the motor that pulls the power out of the battery and if the battery is not able to handle to load it will overheat and possibly get damaged.
with car battery that can handle 500Amps or more there is no risk using in in a starter box that needs lets say no more than 50Amps.
It is just too big and heavy to be dragged around
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 01-16-2010, 09:12 AM   #7
Zerodefect's Avatar
You can fit 2 Turnigy 30c 4S 5000mah packs in parrallel into a Ofna Truggy starter box.
Thats enough power to totally dismember your pit guys hand and snap the conrod of every motor on the track. Should go for a half dozen racedays between charges as well.
Zerodefect is offline   Reply With Quote
Old 01-16-2010, 09:16 AM   #8
kaptain crash's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to kaptain crash
I hook my lawn-mower battery to mine ....12 volts is 12 volts.
kaptain crash is offline   Reply With Quote
Old 01-16-2010, 09:42 AM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
I saw one of these last week at the track. They are a little hard to move around in pit lane and they are very very heavy. Why not just use a 4s lipo the one mentioned above is actually cheaper than a car battery. But you only need 1 - 4. At a time. That's more than enough power.
Old 01-16-2010, 09:55 AM   #10
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I use protek 4s lipo's in mine. They have soo much power compared to a 12v battery. They are also very light which makes for easy handling of the starter box from the pits into and out of pit lane. They are relatively cheap and hold a charge forever. They also last much longer as far as the overall life of the battery. Well worth it in the long run.
Here is the one I use.
http://www.amainhobbies.com/product_...Ah-Starter-Box
You can find cheaper ones around too. Like the turnigy ones from hobbyking.com
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 01-16-2010, 02:29 PM   #11
j_blaze14's Avatar
i've gone through all the battery options and found lipo to be the best so far. as long as you have a good charger for the lipo and don't have to crank your motor all day to get it started you won't have a problem. if you want you can charge the lipo between heats, its only gonna be like 100mah or so but its good to be safe.
Old 01-16-2010, 02:45 PM   #12
wallot's Avatar
car battery has more surge capabilities than standard lipo
however who would want todrag around big and heavy battery. I use 4S 5000Mah old zippy-h. I charged it before start of the season and in the middle charged it once
KoPropo Eurus
Losi 8ight Starter Box Troubles yellowfive-o Nitro Off-Road 18 10-29-2009 01:08 PM
Mugen MST-1 + starter box Michael_90 Australia For Sale/Trade 7 05-31-2006 02:31 PM
AE NTC3 Starter Box w/12V Batt & Auto Charger NTC3NUT R/C Items: For Sale/Trade 10 06-07-2003 01:29 PM
