rc8 shock help
rc8 shock help
guys i'm having a hard time setting the rebound on my big bores on the rc8, if you screw the cap on with the shaft set at a certain position, it will never rebound there
i'm just mad at myself for not being able to do this
There definatley is a trick to it. I found that I set the shock shaft/piston to the rebound location I want, make the sure the cap is two full turns open from being fully closed, then tighten making sure the shaft does not move.
The shaft will return a little more than where I set it, so I will adjust for that when I tighten the cap.
Hope it helps.
Hope it helps.
thanks man, i found that also when trying this last night
i will try it again tonite, and post back if i need more help
thanks
thanks
