Old 01-13-2010, 08:05 AM   #1
Default Hit a wall today - Pulling to the left
Hi chaps, I hit a wall with my truggy today. Everything looks to be in order, yet it's now pulling to the left quite markedly. I've had the wheels off, and taken a quick look at everything, but I can find no damage. Put the wheels back on and it's still pulling left.
Is there an adjuster somewhere on the car, that could've been knocked? Or what should I look out for, as there's obviously something causing the problem
James
Lawson1024 is offline   Reply With Quote
Old 01-13-2010, 08:08 AM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
James
Bent servo arm? Bent linkage? Damage to the suspension that isn't immediately evident? Bearing problem on the left side?
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-13-2010, 08:08 AM   #3
DPowers's Avatar
Trader Rating: 79 (100%+)
James
Its probley your trim on your radio check that first.
DPowers is offline   Reply With Quote
Old 01-13-2010, 08:30 AM   #4
Everything looks to be in perfect condition :S Ah well, I'll adjust the trim and hope for the best
Old 01-13-2010, 08:48 AM   #5
Is the chassis bent?
Maybe the servo horn skipped a spline on the steering servo at the time of impact?
If everything was fine before and now it isn't there is an issue - servo trim shouldn't change.
HiVoltg12 is offline   Reply With Quote
Old 01-13-2010, 09:16 AM   #6
It wouldn't take much of a bend in the steering rod to adjust the steering to that wheel quite alot.
Adjust the steering rod to give you the toe out that you require.
Set the car on a box, turn on ya radio gear and look how the wheels sit. Then adjust so that they both slightly toe out.
Another thing to check is ya suspension. If it's drooping more on one side, the car will pull to one side.
Flipfly is offline   Reply With Quote
Old 01-13-2010, 09:18 AM   #7
losiracer78's Avatar
Sounds like you stripped a servo horn spline. Dont think so but might have stripped a servo gear alittle and it offset the servo
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 01-13-2010, 09:49 PM   #8
merdith6's Avatar
Default Check the servo saver too...
If the servo saver is worn or loose it can cock to one side in a crash, take it apart and check for wear or dirt or a loose setting. Put some dry lube on it. The tephlon spray from Lowe's. it works great for stuff like that....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 01-13-2010, 10:01 PM   #9
Cory Kerber's Avatar
I also think the servo horn may have skipped a spline.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 01-13-2010, 10:32 PM   #10
MontanaMaxx's Avatar
sometimes the ball ends move on the shaft also making link longer or shorter which changes the whole alignment i would venture to say its this or servo horn jumped a spline
MontanaMaxx is offline   Reply With Quote
Old 01-14-2010, 02:20 AM   #11
Ok (and I'm new to this, so stay with me) what's a servo horn, and how do i know if it's skipped a spline?
Old 01-14-2010, 02:47 AM   #12
It's the arm ON the servo. Pull it and check it. Re-center it and away you go. If that don't work look close at the ball ends. Might have pulled one.
The Working Man is offline   Reply With Quote
Old 01-14-2010, 04:39 AM   #13
DOMIT's Avatar
If the servo horn skipped a spline, it's trashed. Put a new one on. (Use aluminum... that won't happen again!)
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 01:41 PM
