Old 01-10-2010, 03:47 PM   #1
Default rear wheels do not spin
guys today i was driving my car and the rear wheels started to not spin. if you give it alot of gas you have to wait like 5 seconds for them to spin. whats with that?
rccarsrock is offline   Reply With Quote
Old 01-10-2010, 03:49 PM   #2
need more details. what car etc..
terminalpvd is offline   Reply With Quote
Old 01-10-2010, 03:52 PM   #3
its a off road buggy. tornado s30. it is made by redcat. i got it since christmas and drove like a total of 18 tanks maybe?
Old 01-10-2010, 04:43 PM   #4
houston's Avatar
Trader Rating: 91 (100%+)
probably sticking rear brakes
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 01-10-2010, 05:31 PM   #5
w_kirk_jr's Avatar
Send a message via Yahoo to w_kirk_jr
a couple guys bought those off some online store neer our track dose it give a jerk wen the rear weels start pulling if so then replace the rear diff if not then loosen ya bias on ya rear brakes
WILLIAM KIRK JR-
WWW.DIXONSRCRACEWAY.COM | SIDEWINDER | TEAM EPIC | A-MAIN HOBBIES
WWW.MYHOBBYDEPOT.COM
push aginst me! It only will make me stronger and faster-
w_kirk_jr is offline   Reply With Quote
Old 01-11-2010, 02:27 PM   #6
it is definitly not the brakes! when i press the throttle all the way, the thing goes to where its supposed to. so the brake is not stuck. the thing would not move at all if the brakes were stuck
Old 01-11-2010, 03:47 PM   #7
sounds like your wheel bearings are locked up.
Lets hope that's what it is. Because the other problem (not shimmed or meshing properly) could be a bigger problem. It could also be your universal joint cups etc. But my bet would be rear bearings.
Does it lock up then unexpectedly free itself? Or is it just stuck like permanently?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 01-11-2010, 06:00 PM   #8
Grimlock212's Avatar
If the bearings are an issue won't it cause problems just rolling it? Do the rear wheels bind when trying to roll it?
I am guessing it is something else since it is unlikely that the bearings on both side would go at the exact same time.
Grimlock212
Losi 8ight 2.0: Clockwork Racing Engines JLR .21, Hitec 7955tg x2, Spektrum DX3S
Losi 8ight-T 2.0: Clockwork Racing Engines JLR .21, Hitec 7955tg x2, Spektrum DX3S
Losi Ten-T: 7/7/2, Kingpin tires, optional Losi Springs, Spektrum DX3S
Nor-Cal Hobbies: Union City, CA
Grimlock212 is offline   Reply With Quote
Old 01-11-2010, 07:01 PM   #9
if you give it full throttle it takes a few seconds for them to spin. my guess is the transmission.
Old 01-11-2010, 07:06 PM   #10
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
center shaft grub screw. highly doubt its brakes or rear diff.
that or axle pins falling out, broken, or missing from factory (some of those cheaper cars have those kinda QC issues)
R
UltegraSTI is offline   Reply With Quote
Old 01-11-2010, 07:38 PM   #11
that is also what i meant.
Your hubs, cvd etc are not connected
Mugen
Old 01-12-2010, 12:09 PM   #12
I agree with the wild guess that a set-screw is loose. Maybe use a little thread lock when you figure out which one is loose.
Grimlock212
Balancing Truggy Wheels SKOT Nitro Off-Road 40 02-28-2010 06:56 AM
4WD Setup...Diff Front, One way Rear? haulin79 Electric Off-Road 25 07-24-2008 11:41 PM
Why no one-way or spool at rear? Aku-Man Electric On-Road 6 04-18-2004 04:56 AM
