Old 01-09-2010, 10:54 AM   #1
Default Servo dying?
I was running my 8ight 2.0 around today and all of a sudden the throttle and brake servo just quit working. The battery in the RC car was fully charged. I took it back to the house and started looking at it and nothing appeared to be wrong with it. The steering worked just fine.
So I took the steering servo wire and plugged it where the throttle steering wire was and the throttle trigger now controlled the steering. I then placed the throttle servo wire into the steering slot on the RC cars receiver and the servo didn't work. I placed everything back to the way it was originally.
I pulled the throttle full and the servo didn't move. I "helped" it and it moved. I let go and it didn't go back to the neutral position. It just sat their full throttle. I then helped the servo back into neutral position and it snapped into place. I turned RC electronics off and turned the servo by hand to see if the throttle was really bound up but it seems to be just like normal. Not really hard at all the turn.
Is this a sign of a dying or bad servo?
I have been having some issues with electronics on this car but I think this is a different problem all together.
Possible electrical issue
kur1j is offline   Reply With Quote
Old 01-09-2010, 11:02 AM   #2
jjshbetz11's Avatar
ya sounds like its going is this the stock servo? If it is your just one of many let down by it. Remember to set EPA correctly, noticed without them set corrrectly my servo will serisouly flex the servo tray when applying breaks. Now thats too much stress on a servo. Set throttle epa (if your running a venturi inside the carb) so the slide just clears the venturi. For break, so it applies breaks to your liking.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 01-09-2010, 11:49 AM   #3
I am not sure what "EPA" is.
Which server would you recommend to replace it? Would you recommend replacing the steering servo as well while I am at it? What servo(s) would you recommend?
Old 01-09-2010, 11:55 AM   #4
jjshbetz11's Avatar
EPA is end point adjustment. Basically it limits the travel your servo can travel. Turn your electronics on and turn the wheel on transmitter all the way to the left or right. Do you hear the servo making noise when its fully turned? Thats your servo trying to turn the wheels further but the wheels can't go further left or right. U can adjust it so the servo stops at the point where the wheels stop turning so your not stressingthe servo. Got me? I would recommend HITEC servos. Now for witch one is up to you. Just keep in mind with servos what U pay for is what you get.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 01-09-2010, 11:59 AM   #5
jjshbetz11's Avatar
Dang my typing is wack
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 01-09-2010, 12:12 PM   #6
Sorry I am pretty clueless about which servo to get could you give me a few of the standard "good" servos to replace them with?
Old 01-09-2010, 12:30 PM   #7
Integra's Avatar
Spend BIG once and Never look back.
Hitec 7955 and be done with it.
Old 01-09-2010, 12:51 PM   #8
My current servos are as follows.
Spektrum Z270 for throttle
Torque: 43 oz/in @ 4.8V, 49 oz/in @ 6V
Speed: .23 sec/60 @ 4.8V, .19 sec/60 @ 6V
Dimensions (WxLxH): 0.73" x 1.55" x 1.46"
Weight: 1.50 oz
Motor Type: 3-pole ferrite
Gears: Nylon
Spektrum Z590 for steering
Torque 85 oz/in at 6V
Speed .15 sec/60 at 6V
Dimensions 0.73 x 1.55 x 1.46in
Weight 1.6 oz
Obviously any of the following would be more than enough as the 7940 has almost double the torque and is twice as fast as the Z590 that is currently on it.
I'm not real sure of the difference of these servos other than the obvious speed and torque.
Other than the ~5 dollars why wouldn't I use a 7950TG over the 7955TG? The 7950TG is quicker than has more torque.
http://www.servocity.com/html/hs-7940tg_servo.html
http://www.servocity.com/html/hs-7950tg_servo.html
http://www.servocity.com/html/hs-7955tg_servo.html
Also wouldn't I want to use the 7940 for the throttle and the brake and the 7950 or the 7955 for the steering?
Old 01-09-2010, 12:54 PM   #9
jjshbetz11's Avatar
That website is a good find thanks
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 01-09-2010, 02:03 PM   #10
Integra's Avatar
Weight: 1.50 oz
Gears: Nylon
Weight 1.6 oz
Im still not 100% sold on the new HV's....the 40's have been having failure's and the 50's seem to be a little more robust but the reason i recommend the 7955 is the fact its proven bullet proof over and over again.
IMO Fast throttle servo's are overrated and not needed...i run .15 on my throttle and it's just fine and dandy.
Old 01-09-2010, 02:21 PM   #11
whats the difference in the TG and the TH?
7950TH or the 7950TG?
Old 01-09-2010, 02:28 PM   #12
losiracer78's Avatar
Jr9100t for steering
Type: Ultra High-Torque Digital Servo
Torque: 300 oz/in @ 4.8V, 370 oz/in @ 6V
Speed: .18 sec / 60 degrees @ 4.8V, .15 sec / 60 degrees @ 6V
Dimensions: 0.83" x 1.59" x 1.57"
Weight: 2.3 oz
Gears: Metal Gears
jr9100s for the throttle
Type: Digital Ultra-Speed Metal Gear Servo
Torque: 150 oz/in @ 4.8V, 180 oz/in @ 6V
Speed: .08 sec / 60 degrees @ 4.8V, .06 sec / 60 degrees @ 6V
Dimensions (WxLxH): 0.827"x1.59"x1.569"
Weight: 2.3 oz
Bearing: Dual Wide Spaced Bearing
Motor Type: Coreless
Gears: Metal
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 01-09-2010, 02:39 PM   #13
Integra's Avatar
hitec only list's one 7950TH on the site...but they use both TH and TG in the description......i would assume its the same servo.
Old 01-09-2010, 02:47 PM   #14
I have been using the JR 9111T for 2 yrs. it probably the best
Losi 8
Losi leight
Pinion48 is offline   Reply With Quote
---What Servo's for Full racing! Help Needed!---- jamiekerr14 Nitro Off-Road 54 01-29-2009 06:20 AM
FT B4 for sale! Tires motor servo bodys everthing! jono mad racer Australia For Sale/Trade 49 01-02-2008 12:42 AM
Dying to buy another car......... rc_freak R/C Items: Wanted to Buy 23 10-27-2007 08:20 PM
i am looking at getting a digital servo to go with my radio , what should i get ? gator Electric On-Road 23 10-08-2002 08:31 PM
