Old 01-09-2010, 05:01 AM   #1
savagesam's Avatar
Default Novarossi 21+4 turbo plug help ???
Hi there i have read lots of different comments while searching the forum about correct plugs for engine.
My question is i have a novaroosi 21+4 turbo buttom fitted that i bought 2nd hand ( 1 1/2 litres only ) that had an o.s p4 turbo plug fitted.....
Is this ok for the engine or should i only be using the correct novarossi long turbo plug in this engine or now that it has been run with an o.s plug should i stay with o.s plugs....
Please advise which plugs do fit correctly in this engine for best seal and best glow as each search i did had lots of people saying different things about plugs that fit properly and i would like to complete the run in and get this engine running properly for my new buggy.
Also what pipe is best for this engine purely for racing on an off road track....
- Australian Team Tekno Rc - The Nitro Shop - Nitro X Fuel -
- Proline - Coast 2 Coast Rc - Hearns Hobbies - SMC - Futaba -
- Sam's Youtube Channel - http://www.youtube.com/savagexsam -
savagesam is offline   Reply With Quote
Old 01-09-2010, 05:07 AM   #2
Trader Rating: 24 (100%+)
check out the novarossi thread and you should find what ya need..
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 01-09-2010, 05:59 AM   #3
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
the OS thread taper is different..........get a new button and run Odonnell 97T's
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-09-2010, 10:56 AM   #4
houston's Avatar
Trader Rating: 91 (100%+)
Your choice if you want to get a new turbo underhead part#28002 and run odo97t or just keep running os plugs now that it has an os plug installed . If you go back to nova/odonnell plugs there will be a slight leakage causing low compression . I say stick with the os plugs and use either p3 or p4. I do not have any experience with os plugs but do know what they consider there plugs as far as different heat ranges.
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 01-09-2010, 11:57 AM   #5
blktransam's Avatar
Trader Rating: 59 (100%+)
I would stick with the P4...thats what I run in my C6 which is novarossi made...
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 01-09-2010, 12:31 PM   #6
KWT-NITRO's Avatar
hi
i run an OS P3 with my plus4 with no problems, just dont switch back to another plug.
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 01-09-2010, 05:03 PM   #7
savagesam's Avatar
Default reply
Thanks guys well the os turbo plugs are the easiest for me to get so i will stick with the os plugs now that it has been started this way by the first onwer.........cheers
Old 01-09-2010, 07:47 PM   #8
losi_racer's Avatar
Trader Rating: 25 (100%+)
i ran os when i first got a +4 and i hated it. wouldnt idle at all. same button i went to nova and never had a problem
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-13-2010, 04:21 AM   #9
savagesam's Avatar
Default reply
I finally ran the engine today for 7 tanks with an o.s p6 plug fitted and had no leaks at all and the engine idled nice and clean and i was getting between 11 and 12 minutes run time from a tank in the hot bodies d8 buggy on our off road track MORRCC..... thanks for the replies guys it was very help full and i find that what works for some people doesnt allways work for every one....
Old 01-13-2010, 06:39 AM   #10
blktransam's Avatar
savage well put, I would think a p4 might work a little better as a p6 is a pretty cold plug for that engine, from what I have read on it anyways...
Ryan
-Ryan Klemme
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
Engine selection help needed!! ASAP Strosek Nitro Off-Road 11 06-21-2008 10:27 PM
