Help me pick a tool.
Looking for a good set of hex wrenches for a small electric screw driver.
Like this.
http://www.amainhobbies.com/product_...river-and-Case
Please let me know your thoughts.
Like this.
ive been using my Ofna set for the better part of the year and they are still working great.
the kit i use is the 9 piece one. it has all the allen drivers, plus a philips, flathead, and socket drivers also. and it comes with a handle, so you can use it in the drill or by hand. i love mine: http://www.amainhobbies.com/product_...ilicone-Handle
http://www.integy.com/cgi-bin/webc.c...90&p_catid=170
these tools have been excellent as well in the hitachi
these are good also
http://www.integy.com/cgi-bin/webc.c...87&p_catid=170
these are good also
these are good also
these are good also
Thanks for the input. I have the first one and that is what I am replacing. I am having a problem on 3 of them that little set screw is not keeping the tips for spinning. So they will not turn anything.
Have you tried the second one yourself? I have one of their other sets with the handle but the end is too small for the small electric drill.
Monty
the only one i have had any trouble with is the 3mm , completely my fault though engine screws on underside of chassis on kyosho w/loctite
btw , those are rolled/shear pins on those tips you musta put a buttload of torque on them
i havent bought the hudy looking set personally but have used a few different peoples tips just to try them out and they were definitely good , cant say that they are any better than my set .
i have had my set for 2 1/2 years , so either i dont wrench my cars enough or the tools are good . i love my hitachi 3dbl
hmmmm crazy !!
I use the Hudy tips in my Hitachi, and i love it. I will NEVER go back to strictly hand tools. The only thing is that the bits are a little loose in the chuck, but i've gotten use to it. They can move forward and back some.
Monty, the Kyosho uses 3mm to hold the engine mount to the chassis? I need some of those, i always strip my 2.5mm.
the integy tips have a divot to lock them in , you pull out the chuck to release the lock on the hitachi and the bits drop and lock
You know every once in a while a bad one gets out. But I had mine for a long time so I am sure I got my moneys worth.
