Old 01-07-2010, 04:41 AM   #1
savageguy1306's Avatar
Exclamation running in sub zero (deg C) temperatures
hi erm was wondering if i need to do anything extra to my picco p3.21b prior to running in cold conditions
savageguy1306 is offline   Reply With Quote
Old 01-07-2010, 07:46 AM   #2
below zero
I ran mine when it was about 30 degrees outside. I took some cotton rags and cut them into stripps. Then i put CA glue on strips of aluminum foil and glued the the picies of rag to it.
Wraped about 2 layers of this on the case and cooling head.
My engine got so hot it started smokin
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 01-07-2010, 07:51 AM   #3
blktransam's Avatar
Trader Rating: 59 (100%+)
no need to glue rags to aluminum LOL...just wrap the head with some aluminum foil, richen up the engine a little bit...keep head temps above 200 if possible.
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 01-07-2010, 08:16 AM   #4
blkstram you laugh but it really really works. I was running WFO, that's why it got so hot. JUst plain foil does not work good enough for me. Especially when breaking in a new engine
Apparently it worked to well
Mugen
Old 01-07-2010, 08:21 AM   #5
Trader Rating: 15 (100%+)
We race every weekend through the winter, it is regularly below freezing on the track side of the building. I usually put a little heat into the engine before start up. I use a heat gun and get the temp up to about 200* F before start up. I always richen up the motor before the 20 min. main. It seems like everyone's motors tend to lean out a little on the longer runs in the cold.
Good Luck!
ridein04 is offline   Reply With Quote
Old 01-07-2010, 08:27 AM   #6
yeah, engine runs REALLY good in the cold
Mugen
Old 01-08-2010, 05:34 AM   #7
Default thnx
cheers guys im in northwest england at the mo like so its really cold like hasnt risen abouve freezing (0 deg C) for days and hve been running for about 1 hour each time tryed both things and didnt seem to start any quicker
but i always let it sit on idle for a good 15-20 mins after start to ensure im at op temps
if u check any world weather forcasters it will say frozen all over britan lol
and i had to richen up loads
Old 01-08-2010, 05:41 AM   #8
Trader Rating: 24 (100%+)
for racing a little tip we do at The Speed Shop is use a thick high quality sock in a kids size. Cut it to fit and stretch over the head. Pre cut a little hole in the top for and you will be good to go. Just make sure to warm the engine before you start and it will probably be in the 200-220 range.
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 01-08-2010, 07:35 AM   #9
lk
Just wondering if the sock might actually melt... Cotton and wool would probably be ok, but what about nylon and the elastic properties of the sock... I really do not want to ruin the nice finish of my motor...
I had a real hard time with the motors at last weekend´s practise with temps around 30f.
lk is offline   Reply With Quote
Old 01-08-2010, 07:44 AM   #10
blktransam's Avatar
no need to let engine idle for 15-20 mins, its not going to get any hotter...let it idle for 1-2 mins then slowly reach wot, a few mins of running it around it should be good to go...
-Ryan Klemme
Tags
cold conditions, p3.21b
