Old 01-04-2010, 05:18 PM   #1
Default In need of Hinge Pins! Help
Hey guys, I just got some used a-arms for my nitro rustler and they are missing two hinge pins that I need. I included a picture of the pin that I need. They are the smaller pins on the a-arm. The stock rustler ones are threaded so they are not used in the conversion. I went to my lhc and they did not stock the hinge pin that I need. I do not really want to buy a $20 set of titanium pins, but I need these pins to run the car! Anyone have any help? I would buy them if someone has a set of extra's!
In need of Hinge Pins! Help-0103001607.jpg   In need of Hinge Pins! Help-0103001608.jpg
thegrimreaper3 is offline   Reply With Quote
Old 01-04-2010, 05:31 PM   #2
helivaguy's Avatar
Trader Rating: 42 (100%+)
i know in the past when i was in a jam i used drill bits or steel pins/dowels and cut to size,i would then drill and tap a grub screw on the a-arm to hold it in place.
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 01-05-2010, 08:02 AM   #3
scwrod's Avatar
so you don't want to spend 20 bucks to get your ride running?
Then get creative or put plastic back on it.
How much did you spend on the arms?? I think that is were you blew your money.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 01-05-2010, 12:10 PM   #4
I bought all aluminum rear a-arms, front a-arms, front shock tower, upper chassis, and rear bearing carriers, all for about $40 . But yes I still don't want to spend $20 on hinge pins so I am going to try and get creative.
Old 01-05-2010, 02:56 PM   #5
hard to believe that hinge pins for a traxxas rustler is 20? when the whole car plus, motor, pipe, servos, radio, starter is all around 200$
I know parts are more expensive, but dddaaammmnnn. Hinge pins on my mugen i know are better quality by a good margin. But they are still less then that. Hell those small pins on the outside should be less then that. Are you sure it's 20$ I find that hard to believe.
shit. Just looked and realized it was titanium. That sux. But that is what you get for having aluminum arms. The stress has to give somewhere. If you put in titanium pins the stress will all be put on your bulkhead or whatever it's attached to, which will probably break next since the arms and pins don't give.
If i were you i would go back to the plastic arms, I know it doesn't have much bling but you would probably be better off.
Have you upgraded your shocks??? A steering servo and big bores should have been you first upgrade. My brother in law has one, so i know how crapy those shocks are.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 01-05-2010, 04:39 PM   #6
scwrod's Avatar
he said titanium pins.
RC Corral in Waukesha RC Corral Wisconsin & Illinois Racing 1671 06-21-2015 08:27 PM
Help buying new 1/8th nitro buggy Jaap Nitro Off-Road 40 10-04-2009 12:44 AM
X6 XFactory in 07 radio_car_racer Electric Off-Road 406 01-04-2009 04:58 PM
"Tamiya Class" racing...Help me choose - TA05 vs TA05R pgeldz Electric On-Road 84 08-09-2008 09:03 PM
