Old 11-04-2010, 04:04 AM   #1021
Originally Posted by kgombe View Post
the prototype used bearings at the mounting points
Where do you mean?
Does that mean the production version will not have bearings at the mounting point. I would like to see pictures...
David1976 is offline   Reply With Quote
Old 11-04-2010, 04:20 AM   #1022
kgombe's Avatar
Originally Posted by David1976 View Post
Where do you mean?
where they would normally mount to the bulk head and you would have to used a set screw to keep it in place or moving back and forth... it made sense not to use bearings... because if you want to go to different sizes of sway bars what would u do then... and sway bars only vary in thickness by .1mm..
or i may have been mistaked.. maybe it was teh serpent that came with bearings... now im not sure.. somebody will clear this up...
kgombe is offline   Reply With Quote
Old 11-04-2010, 06:10 AM   #1023
jzemaxx's Avatar
The serpent does indeed use ball bearings for the swaybars. They work awesome. By far the best way of mounting the swaybars and eliminating all slop and any side to side movement. The sway bars are held by a grub screw coupler with the ball bearings so you can easily swap to larger or smaller swaybars without a problem.
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 11-04-2010, 06:27 AM   #1024
kgombe's Avatar
thats right... now i rem how it was mounted... and what car... ok thx.. CRS is kickin in..
Old 11-05-2010, 01:00 PM   #1025
FMLinero's Avatar
Default Team Durango DNX408 Skid Plates
http://www.team-durango.com/blog/?p=1851
Good Luck!
FMLinero is offline   Reply With Quote
Old 11-05-2010, 02:30 PM   #1026
fullsyzz's Avatar
Trader Rating: 102 (100%+)
fullsyzz is offline   Reply With Quote
Old 11-05-2010, 02:41 PM   #1027
The kit release is imminent it says on their website. Should not be too much longer!
ironpeddler is offline   Reply With Quote
Old 11-06-2010, 04:02 AM   #1028
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I think this would look good parked next to the DEX410...hmmm
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 11-06-2010, 05:52 AM   #1029
Send a message via AIM to mazzinga
+1
mazzinga is offline   Reply With Quote
Old 11-08-2010, 09:49 PM   #1030
Have Durango issued a date when it will be released for sale????
RCRACER2X is offline   Reply With Quote
Old 11-09-2010, 02:13 AM   #1031
From what I know the cars is on the way for distributors (not confirmed 100%)
Old 11-09-2010, 07:11 AM   #1032
I haven't called amain this week but last Friday they still had no idea of when it was going to be released or at least they said. I hope you are right though.
Old 11-09-2010, 07:26 AM   #1033
kgombe's Avatar
Call HRP
Old 11-09-2010, 08:27 AM   #1034
Call HRP
They said end of the month.
Old 11-09-2010, 08:28 AM   #1035
kgombe's Avatar
cool
