Old 01-03-2010, 12:09 PM   #1
Default fluids/bearings/glo plugs
Need to replace these all on my Losi 8ight T 2.0 RTR
DIff fluids, shock fluids, engine bearings, glo plug.
The Losi owners manual recommends losi fluids and Dynamite Glo Plugs
Do you guys recommend buying the parts losi reccommends or is there anyting better out there? What glo plugs should I run in the 454 engine? is there an advantage to running shielded bearings over sealed?
ncstater6 is offline   Reply With Quote
Old 01-03-2010, 03:41 PM   #2
steve307b's Avatar
Trader Rating: 23 (100%+)
I use Losi diff fluids and shock oils. But any brand will work. I would say to just replace fluids with what the manual says to start with and then when you learn a little more you can change it up.
8ight-T 3.0 **FX Royal Engine** 2013- Savox 1267/Hitec 7950
Henchman racing
DX4R
steve307b is offline   Reply With Quote
Old 01-03-2010, 05:36 PM   #3
merdith6's Avatar
Default I like..
The Associated shock and diff oil, it's cheap, and works good. Try the McCoy Mc8 glow plugs they have been around for years and work in any standard glow plug engine, minus the O.S. engines....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 01-03-2010, 08:07 PM   #4
I don't see any mccoy mc8 plugs on A Main Hobies... How do I know whether to choose a hot or cold plug? I am running 30% Odonnel Nitro on the .28 engine.
Old 01-03-2010, 09:36 PM   #5
imaxx21's Avatar
Send a message via AIM to imaxx21
http://www.amainhobbies.com/product_...um-Glow-Plug-1
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 01-03-2010, 09:41 PM   #6
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Best deal period
http://trackstarrc.com/trackstar/ind...hk=1&Itemid=64
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 01-03-2010, 09:44 PM   #7
merdith6's Avatar
Default Plugs
Well that is long story probably told by another. Usually cold plugs aren't so great on idle, and hot plugs tend to be for turbo style engines, and medium seems to work best for most applictions. It's a good start. Novarossi makes a medium nunber 6 plug that works good, but it's expensive. I like the mccoy plugs for their price and great performance. the 8 is the medium. It realy confusing. You can't go by the numbers across different brands. The odonnell sport medium glow plugs are the best price at like 4 dollars, but I haven't used them to say for sure. All I know is I put the mccoy 8 plug in every engine I've had with great success. from .12 engines all the way to .21. the .28 will be the same.
Old 01-03-2010, 09:45 PM   #8
imaxx21's Avatar
$8 for 4oz?
how is that the best deal?
-Crash
Old 01-03-2010, 09:47 PM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
I use Losi shock oil and diff fluid and OS engines like OS plugs. I like to run P3 plugs in my .21 engines and P4 work well too.
Old 01-03-2010, 10:51 PM   #10
yuppi1's Avatar
i use associated oil in my shocks and diffs, seems to work well for me and half the price. as for glow plugs i will only use o.s plugs as i think they are good quality and readily available.
yuppi1 is offline   Reply With Quote
Old 01-03-2010, 11:16 PM   #11
Originally Posted by imaxx21 View Post
$8 for 4oz?
The quality of the fluid far surpasses what is available from AE or Losi,
Is absolutely consistent from bottle to bottle,
and comes in a 4 oz "big bore" bottle.
(and you will probably see the price come down as we are now able to buy large batches = less expensive)
Jimmy Wright
Old 01-04-2010, 02:04 AM   #12
$8 for 4oz?
I don't see me buying 2-3 hundred $ worth of shock oil any time soon so that isn't a deal. You need to be a small biz operator with a good write off to do that.
The Working Man is offline   Reply With Quote
Old 01-04-2010, 10:50 AM   #13
merdith6's Avatar
Default BS
It's silicone oil, how much quality is needed. I can hear the sales pitch...At D&f we have strict quality control standards that routinely check the viscosity of each batch ensuring top quality and cst, wt standards along with 99.99999999 percent purity levels, each day Juan Valdez hand pics the silicone beans at 4 am when they are at their peak of freshness, give me a break. Team associated has been making oil for what 25 years, and it's lik 3 dollars. Give it up....
Old 01-04-2010, 11:23 AM   #14
The stuff Jimmy sells is actual CST ratings oils.
AE 25wt is labelled as 275CST, but is actually 286.
With the oils that Trackstar sells what ever cst is on the label that is what the fluid inside actually is. The label is not an estimate it's a fact.
The Lutzinator uses it too so it can't be that bad
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 01-11-2010, 03:49 PM   #15
trackstarlosi's Avatar
AE is a huge company and with huge comanys come failures also. jimmy does own a small buissness right here in southern california. its like eating a a little hole-in-the wall taco shop over del taco. quaility is always better when you go smaller
Dylan Elliott
TLR Team Losi Racing / Novarossi / Nitrotane / Spectrum
trackstarlosi is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
