Motor shimming?
Ive noticed on some of the threads that has been posted on hear about shiming such as if you run 30% then you need to have atleast 3 shims and if you are running 20% then its less so what is a simple way of knowing how to shim a motor and the amount of thickness they need to be. Cause what I belived to be right is starting to sound way wrong I just thought the less shims that you had then the more compression but from the few threads Ive seen it sounds all wrong.
you need to shim for the fuel...
it should specify in the motors manual.. most race motors now come with shimming for 25-30% the best way to know is to get some solder bend in in an L shape stick it down the glow plug hole and turn the motor over measure the head clearance (how smashed the solder is) and re shim according to fuel percentage. |
My motor is a Axe Rosi Mammba Evo x1 The instrucions was very vague meaning it did not mention that just said the fuel and oil content mix it is made for 30% witch I am running 30% Byrons fuel
Now could you give me the diameter of soldering to use and what the shiming should be for the amount of mash that is done to the solder Now that I have heard before with the soldering just forgot the diameter to use but did not know that the amount of mash could give you the indication of how much shim to use |
Originally Posted by kodiakbear7070
(Post 6794432)
(Post 6794432)
Now could you give me the diameter of soldering to use and what the shiming should be for the amount of mash that is done to the solder Now that I have heard before with the soldering just forgot the diameter to use but did not know that the amount of mash could give you the indication of how much shim to use General rule is .023-.025" clearance is a good start for 30%. |
Originally Posted by Racecrafter
(Post 6795219)
Use 1/16" (.062) or close for solder. I prefer non flux core as you get a better measurement.
General rule is .023-.025" clearance is a good start for 30%. .19-.22 is good for 20% right? |
Originally Posted by smokinu
(Post 6795241)
thanks jimmy i have this thread bookmarked now,
.19-.22 is good for 20% right? .1mm = .004" Just be careful and pay attention to plug readings. |
(Post 6795265)
Uhm Yes (.019-.022) :)
(Post 6795219)
ae rossi x1 comes shimmed for 30% should be a 3 or 30 on the top of the head button
Thanks reply sent
