Old 01-01-2010, 10:19 PM   #1
Default Throttle return spring?????
Do throttle return springs work just as well as fail safes? Or should I buy a fail safe just to be safe? Can someone post a pic of their throttle return spring and what they used for it?
Thanks.
crockpot7 is offline   Reply With Quote
Old 01-01-2010, 10:22 PM   #2
if you dont have a fail safe get one.
If you have a fail safe, use rubber bands or springs (i prefer bands), because a failsafe only protects you with loss of transmitter power or range.
If you don't use bands, you can still get a runaway with a dead reciever or a servo glitch (water)
USe both.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 01-01-2010, 10:24 PM   #3
jmaxey51's Avatar
USe both.
+1
i use both rubber bands and the spring. you need the ruber band bc is the linkage pops off some how it will return to idle easily.
jmaxey51 is offline   Reply With Quote
Old 01-01-2010, 10:35 PM   #4
Mugen
Old 01-01-2010, 11:03 PM   #5
can someone post a pic plz?
Old 01-01-2010, 11:04 PM   #6
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
Now how do you mount the rubber bands so that it works as a back up method I have never heard or seen this done.
kodiakbear7070 is offline   Reply With Quote
Old 01-01-2010, 11:07 PM   #7
can you see the pic i put up? or do i need to go to photobucket.
Mugen
Old 01-01-2010, 11:13 PM   #8
No can not see the pic posted up there
Old 01-01-2010, 11:13 PM   #9
here ya go!
Mugen
Old 01-01-2010, 11:16 PM   #10
Thanks for the pic
Old 01-01-2010, 11:19 PM   #11
Is that the Mugen Ninja motor jx .21 also on the rubber would you use something from a newspaper or would recommend something a lil bit stronger
Old 01-01-2010, 11:21 PM   #12
Cory Kerber's Avatar
Go to a walmart, target, heck even a CVS, or Rite Aid, and get a 75 pack of Goody Ouchless hairbands. Those work good, and are cheap for the amount you get.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 01-01-2010, 11:25 PM   #13
ninja motor in a mbx6. I went to the dollar store and bought a bag of pretty small (bout the size of a quater) and pretty thin. I put 2 sometimes 3 on there depending on how much force i want.
Just put it on there, if it doesn't pull the throtle and servo back with ease add another one. Keep doing it till it pulls it shut with no problem.
A bag of a couple of hundred cost 1$ but could save you hundreds in repairs.
Mugen
install a throttle return spring Sylvain Nitro Off-Road 32 05-05-2012 11:32 AM
Throttle Return Spring Problem helgso Nitro Off-Road 17 08-10-2009 11:05 AM
Throttle return spring on 1/8 buggy RGraves Nitro Off-Road 40 03-27-2009 05:41 AM
throttle return spring spudly12 Nitro Off-Road 10 10-24-2008 02:32 PM
