M11 2.4Ghz
M11 2.4Ghz
I got the M11 with the FM set up still in it.
http://www.amainhobbies.com/product_...eceiver-M11-M8
Does that make it the same as the M11 they are putting out now? Thanks.
That module and receiver from A-main I would buy asap. You will have more track time because your not waiting for someone on the same channel as you. You also will have no radio glitches at all. I had great luck with my original M11 and that module setup.
Well I noticed on amain they have an M11 with 2.4 and an m11x with 2.4... What's the difference? I've been having issues with my stuff twitching and I feel some lag out on the track. I'm not sure what the issue it tho. =X
the difference is the M11X is 2.4 only. Its built into the radio, not a normal radio with a 2.4 module
i love mine, its one of the best you can buy. More top pros use it over any other
Very expensive though isn't it? 0.0
i have the m11 that has been converted to the 2.4 and i love it. no twitches or anything very fast response and everything. the reason you have glitches and lags is because its still an FM radio. i would switch as soon as you can. you wont ever have any interference or anything its worth the money. i used a m11x and personally i didnt like it as much as my plain m11. i didnt like the wheel it felt smaller, it just felt different but maybe im just too picky. but switch to the 2.4 and you wont have anymore problems.
