EB Mods JS Racing TX-521R VOX COMP. Motor
#61
so the stock and full mod are both awesome, just different power bands? why not sell them as a buggy and truggy version so people are a bit less confused? the 521r-b and the 521r-t, tada!!
where are pics of these motors?
#62
ok guys i c alot of you askin between the full mod, race prep, and stock so corect me if im wrong edd or joe. but the guys that are lookin for this motor to put in there truggy should b lookin at the stock or race prep as the full mod motor does produce more top end but the bottom end is more linear and (smooth) might not give the kick you lookin for in the truggy. at least this is what edd explained to me this past summer when i was lookin at the ebm5's for my buggy&truggy. there for iv got a full mod for my buggy and a race prep settin down at edds to pick up monday. also the race prep does include more on other engines as you can c on his webpage but cing that he pretty much developed the motor i think its just a break in process he does but not sure on that so don't quote me on it
Joe, I pitted for Tracy last night.. Boy was it cold. 27-degrees to be exact at the time of the mains.. He's running the stock version if I'm not mistaken..I saw the question being posted about the stock version, asking if it had enough power to move a truggy.. His motor is still new and throws his 6t around like it's nothing.. Without a doubt this motor is gonna be popular.. We all know anything ED does is second to none...BTW looks like 9-10 min pit stops will be possible
#64
Hi all, i am looking into running the JS stock motors in Australia and was wondering what the best pipe to run is?
Someone said the 086 works well so i checked them out and found the dynamite 086 which looks the goods but dose not seam to have an EFRA number on it so as far as i know it is illegal to run here in Australia!?
Wat are some of the other pipes that work with this motor?
Also head shims? Do i need to re-shim for 30% nitro? (might be some good ones for Ed Bridges to answer)
Thank you in advance....
#65
Also wat is the bearing size on this motor?
#66
http://www.amainhobbies.com/product_...pe-No-Manifold
http://www.amainhobbies.com/product_...ort-w-Manifold
#67
The engines are shimmed for 30%. To get the best out of the engine the 086 is best and a P4 plug.
Bearings are 7x19x6 front and 14x25.4x6 rear
Engines are in stock at TKO.
http://tkocompetitiondev.com/product...roducts_id=422
#68
#69
the full mod engine will have more overall power and rpm over the stock and race prepped versions. With that being said the full mod will have more linear power band. The full mod engine is prob better suited for buggy, and either one would work great in truck.
Nice! yes Tracy's has a race prepped engine, and 9mins should be no problem.
#70
No. the modified engine has MORE power, but the powerband is smoother then the stocker. The FM is more linear..
