Old 12-30-2009, 04:50 PM   #1
cary's Avatar
Trader Rating: 67 (100%+)
Default What Tires Should I Get To Run At The Nitro Pit
This is for you guys that run at the Nitro Pit AZ.
some friends and I are coming down for the Nitro Challenge in Feb.
what tires should I get for the Buggy and Truggy
thanks
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 12-30-2009, 04:53 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
thanks
this is a very tough question as there are excellent tires from every manufacturer . i can tell you that AKA will be amongst the highest ranked/used tires at the pit
i love this place , see ya there !!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-30-2009, 05:52 PM   #3
cary's Avatar
I was hopping that we could get a little more specific
I like AKA and Pro-line but like gridirons calibers 1/2 ups
brands are a start
Old 12-30-2009, 06:14 PM   #4
Integra's Avatar
I would also like to know this so i have a general idea of what guys are planning to run....i got most of everything but sure cant BRING everything with me.
Ive been told you need wet tires and Dry Tires....you never know what the track condition might be when your heat rolls up so ive been told its wise to have both set's on hand in case the track changes prior to your quali or main.
What treads you running guys ?
Old 12-30-2009, 07:17 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
It will be Febuary so its kinda chilly, stick to Soft compounds.
AKA I beams rear and either Crossbrace front or Cityblock front depending on how much front traction you want and how much speed you carry into your turns. These combos work best on a moist or wet track. If its dry but loose top soil Crossbrace all around, and when it blue groves, pretty much all the blue groove tires work, but stick to AKA as the mains are long
People like Proline Calipers, I-Beams and Crimefighters as well or combos.
I hear some other tires that have similar tread patterns work well also but those are the only tires I have ran. Keep in mind I drive Novice class and am Giving my opinion, but I am sure one of the pro drivers will chime in soon enough, and they mostly run the same tires anyway
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-30-2009, 07:44 PM   #6
losi_racer's Avatar
Trader Rating: 25 (100%+)
BUGGY:
Ive only med city blocks and soft ibeams as far as aka goes. They work ok. Ibeams worked very well, this was actually my fav tire for a while, it worked decent in dry conditions and great in wet conditions. City blocks were so so, they did work but not consistent. Ive also ran m2 and m3 bow fighters. This is a great set up, just make sure you cut the outside edge on the crime fighters or you will be traction rolling, If it drys up run bowties all the way around.
The one tire i am in LOVE With is losi eclipse. This is the only tire i am buying from now on for buggy. Run greens when its wet and red when it dries out. if you want a little more turn in run xbt up front with the eclipse in the rear. The eclipses all the way around turns in great already but the xbts do add a little. All the losi pros and most of the fast int losi guys are running these.but make sure you bring 2-3 sets depending on how much you will be driving, they do wear sorta fast but i mean i have 1.5 hours on a set but they are gone now
TRUGGY:
I have not ran any aka for truggy so i can not comment on those. What i have found out to work well in all cond. is m3 bow fighters. But what most people have turned to are m3 calipers,these also last forever, i kept track of my first set that had 4 hours on them and still usable for qualifers. I will have both of these in my tire bin for nitro challenge.
Hope this helps. I run at the pit weekly and i am a fast int driver. Cant wait till feb
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 12-30-2009, 07:47 PM   #7
Unsober1's Avatar
Tires have alot to do with how you drive and setup yr truck.
Just look and see what others commonly use for a starting point. and then hit the local hobby shop up for parts !!!
The pit is not my local track, so maybe others can be a better help.
Last year I ran truggy and did like the bow-fighter or city-beams ( cross brace was not out fro truggy at that time ) for the first day or so. But for the main I ended up going with cityblock all around. I loved that track and cant wait for this year. I finished in the B-main last year.
I'm no pro, but do know that tires are just about the biggest setup/tuning option you can do for yr truck.
Fusion Motorsports----- www.novarossiusa.com
AB Mods ----- www.abmods.com
Unsober1 is offline   Reply With Quote
Old 12-30-2009, 08:35 PM   #8
az00lude's Avatar
I have ran many different combo here and I like the holeshot best when track is a little damp. Gridirons would work too. Bowtie type tires will always be safe bet all around. During the day, it will be a bit dry so plan on running harder tires during the day.
Xray xb808
az00lude is offline   Reply With Quote
Old 12-30-2009, 09:18 PM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by losi_racer View Post
BUGGY:
TRUGGY:
So you guys arent running like grid irons or holeshots, thats interesting. Personally I bring everything I got, caliber, gridiron, 7's, eclipse, xbt (my fav combo on the buggy top secret M. Truhe stuff) cross brace, i-beam, city block, cross hairs etc... you never know what you are going to like.
BTW nice nice thread Cary. Imon that train hehehe
Old 12-30-2009, 09:23 PM   #10
houston's Avatar
city blocks are awesome buggy/truggy , grid irons are faster for most of the track conditions . losi eclipse tires are another very very good tire
Old 12-30-2009, 09:32 PM   #11
imaxx21's Avatar
Send a message via AIM to imaxx21
i liked holeshots wet or dry (m3)
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 12-30-2009, 09:41 PM   #12
Frank L's Avatar
Thats what I thought. I recently started running ss grid irons and they are great on well groomed tracks (like the nitropit).
Old 12-30-2009, 09:46 PM   #13
xxxtcr's Avatar
Trader Rating: 15 (100%+)
jconcepts 7's for buggy and truggy, give them a try, you wont be disappointed
Jason Miller-Havasu R/C Raceway Track Director
RC8B Sidewinder O.S. XZB Proline tires and body
RC8T Sidewinder O.S. XZB Proline tires and body
4x4 SC10 tekin 4600kv rx8 Sc10 Tekin R5 8.5, B4.1 Tekin R5 8.5 Sikk LidZ(MANGOOOO!)
Team Driver: Team Associated, Proline, Pro-Match, XPS, Morgan Fuels, Tekin Electronics
xxxtcr is offline   Reply With Quote
Old 12-30-2009, 09:49 PM   #14
Frank L's Avatar
I tried the 7's on my buggy and it was all over the place I didn't like them at all.
Old 12-30-2009, 09:54 PM   #15
dishsoap's Avatar
I am a novice driver but AKA I-Beams all around are my favorite. I have run calibers and didnt like them especially right after water. Seems the dirt cakes in the tire grooves and traction is lost.
I-Beams work well in both conditions and when wet the dirt flies right of keeping the tire clean throughout the race.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
$25,000 NITROCROSS WORLD CHAMPIONSHIPS - Nov. 1-4 @ The Nitro Pit Shocker Racing Forum 356 07-28-2009 02:00 AM
Which one of these 2 r/c's should i get? Zeeshan Rookie Zone 36 03-17-2009 09:08 PM
Which tires do I get....? British Menace Nitro On-Road 22 05-11-2006 06:06 AM
