Old 12-28-2009, 02:21 PM   #1
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Default Replacing Engine Bearings
im replacing the bearings in my engine right now and got the front one in but i guess it wasnt hot enough to get the rear one in so will it hurt the front bearing to heat up towards the rear so i can get the rear in?
thanks for advice!
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 12-28-2009, 02:44 PM   #2
shesha's Avatar
Send a message via MSN to shesha
As a ground rule yes, any heat build up more then the operating temp will hurt my advise is you use a heat gun and the bearing extractor or installer to assit the in the job without causing damage.
Or you can just get a new set and do a new install, I had a bad install once and took the chance of reheating to extract and reinstall properly , the engine leaked and got damaged.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 12-28-2009, 02:57 PM   #3
NochikenStrips's Avatar
300-350F is your mark
NochikenStrips is offline   Reply With Quote
Old 12-28-2009, 03:04 PM   #4
Send a message via MSN to Adim_X
I change rear bearings all the time with the front installed. The front will be just fine. Dont sweat it. Just reheat and use the crank to help pull the rear bearing into place and make sure the front is seated well after rear install. Just take your time and make sure to get the block nice and warm. These motors aren't rocket science. If you were good enough to get em out, you can put them back in just fine.
Privateer:
Mugen MBX7R ECO/Nitro, Hitec, Sanwa, Jconcepts Tires, OS Speed, Bones Fuel, Fantom
Adim_X is offline   Reply With Quote
Old 12-28-2009, 04:43 PM   #5
ok thanks guys. i got it. i dont think it got damaged at all. i guess ill find out this weekend haha
Dylan Gerard
Replacing Engine's rear bearings? MetalShield Nitro Off-Road 7 02-19-2008 12:57 AM
