Old 12-28-2009, 11:41 AM   #1
Tate72's Avatar
Trader Rating: 52 (98%+)
Default Bearing question??
I am about to order some bearings from avid and would like to know what is the biggest difference or which is better between the rubber bearings and the Revolution bearings?
Can anyone give me some input on this?
Team Durango, http://www.team-durango.com/
TrakPower Speed Equipment, http://www.trakpowerusa.com/
DE Racing, http://www.deracing.net/
WWW.JCPRCRACEWAY.COM
Tate72 is offline   Reply With Quote
Old 12-28-2009, 01:25 PM   #2
Trader Rating: 36 (100%+)
Rubber = two rubber shields, one on each side
Rev's = One rubber, yellow and one metal shield.
Rubber shield bearings ( both sides) offer the best in dirt/mud protection, but will limit the bearing's ability to roll.
Metal shields aren't as durable as rubber, but will spin better, generally speaking.
Yellow Rev's offer the best of both worlds. Install the metal shield to the inside, where it won't be exposed to dirt, grit, water, grime, etc.
NitroOB4You is offline   Reply With Quote
Old 12-28-2009, 02:53 PM   #3
shesha's Avatar
Send a message via MSN to shesha
+1 on what he said, you can also look at boca's they have different ones, the best part of rubber shield you can maintain them easily say after 3 or 4 races providing you did not hose down your bug.
Open, degrease, regrease, repack but if the ones you bought are cheap, then dont bother throw them out after 2 races much more efficient that way.
My boca's yellow seal lasted me a complete season that a total of 10 hours running non stop race and at least 3 hours worth of practise just general maintenance and regreasing and repacking and gtg.
Otherwise cheap ones and throw out...
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 12-29-2009, 05:44 PM   #4
merdith6's Avatar
Default I like the full rubber seals
Mainly because the yellow seal is thinner than the black rubber seal and the black seals will last longer, the yellow seals don't seal very well, but are smooth too. If you run on clay the yellow ones, if you run in dirt then black....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Thrust Bearing question straightaway Nitro On-Road 11 08-06-2015 12:05 PM
v-spec p/s and bearing question forty6and2 Nitro Off-Road 24 09-26-2009 01:25 PM
Thrust Bearing Question Please TRFTIM Nitro On-Road 26 05-25-2006 06:56 PM
Bearing question FUK_WRX Electric On-Road 9 06-06-2004 02:41 PM
