Old 12-26-2009, 10:48 PM   #1
Default transponder mounted a little over the side.
is it okay to mount the transponder a little over the chassis for racing. i don't think it can be hit. i need some advice thanks! i have an HB lighlightning stadium 2
www.rc-international-speedways.com
Associated B4 with novak GTB and Velociti 7.5
Corally RDX with tekin r1 and redline 13.5
Preston777 is offline   Reply With Quote
Old 12-26-2009, 11:02 PM   #2
Many cars have the transponder over the side of the chassis but still inside the edge of the rock guards.
As long as it does not look like it can be hit if you get T-boned or rail slide into a pipe spike & hit it you should be good.
Best judgement is do you think a $100 electrical part would be safe where you have it? You can put them where the paper work says they shouldnt go & facing directions they shouldnt face & they still work fine as long as they get correct voltage.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 12-26-2009, 11:07 PM   #3
well like the paper work says go over the chassis but not where you can be hit so idk? i got it mounted a little over the chassis on teh side withe the radio plate
Old 12-26-2009, 11:19 PM   #4
tc5 man's Avatar
try putting it on the reseiver cover thats what i do on my losi eight
Old 12-27-2009, 09:26 AM   #5
thanks guys, i'll try the mounting it on the radio box
Old 12-27-2009, 09:53 AM   #6
fatdaddy's Avatar
Originally Posted by Preston777 View Post
thanks guys, i'll the mounting it on the radio box
yeah, better safe than sorry
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 12-27-2009, 04:02 PM   #7
easyryder's Avatar
Inside the radio box, thats your best bet! Out of the elements is best! Still counts no problem.
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Personal Transponder issues Joneser Electric On-Road 33 01-27-2004 02:58 PM
