Old 12-26-2009, 09:08 PM   #1
Steebo's Avatar
Trader Rating: 17 (100%+)
Default Longest Steering Servo Horn???????????
Anyone know what the longest steering servo horn is from center of the servo mount hole to the center of the steering link mount hole?
I have used a racers edge and it seems to be about the same spacing as stock. I saw what looked to be an Integy on Mayfields Truggy. The stock one needs to be a little longer, Im not getting full travel with the stock one before it hits the side of the servo. RC8T.
Team Associated, Factory Team, Reedy, LRP, Impulse r/c, Upgrade r/c
www.impulse-rc.com
Steebo is offline   Reply With Quote
Old 12-26-2009, 09:51 PM   #2
Integra's Avatar
Hanger 9 has some REALLY long horns.
Old 12-26-2009, 09:56 PM   #3
tc5 man's Avatar
can u use longer servo arm for a losi eight?
Old 12-26-2009, 10:06 PM   #4
Why would you even want to? With anything longer than the Losi horn (most horns will fit but the Losi is a safe bet and durable), you will have to dremel out the black plastic air filter guard and the steering geometry will be thrown off.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 12-26-2009, 10:07 PM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
I would mess with your end points on your radio. On both of my 8's I run then endpoint to where the wheels stop turning and the value is always over 100 usually in the 110-120 range. A longer servo horn will increase the lever mech and make the steering faster. Racers edge horns are perfect.
Old 12-26-2009, 10:10 PM   #6
tc5 man's Avatar
oh ok i was just wordering thats all
Old 12-26-2009, 10:16 PM   #7
tc5 man's Avatar
120 epa i tried that before and some servos i had ethier hit the steering, knuckles and stress the servo out . i adjust it where its getting full throw
but not where its hitting the steering block.
Old 12-26-2009, 10:17 PM   #8
Frank L's Avatar
Yep thats what I am talking about.
Old 12-26-2009, 10:33 PM   #9
Each raido is different so 120EPA on a Futaba or KO Propo is not going to be 120 on a Airtronics or Spektrum.
Old 12-26-2009, 10:45 PM   #10
tc5 man's Avatar
oh i dint know that, i been running by futaba 3pk for about 4 years.
i had radios that only go to 100% steering epa.
i did realize that if you add lets say, 2 degree toe out in the front u have to reduce the steering epa. i dont think really that u will use full throw while, your racing it only takes like ,steering to half way to get a buggy to turn.
Old 12-26-2009, 10:47 PM   #11
rccardude04's Avatar
Send a message via AIM to rccardude04
These guys make some pretty gnarly arms...
http://www.swbmfg.com/
Typically used in giant scale extremely high performance aircraft, but hey if it's what you need... LOL
-Eric
rccardude04 is offline   Reply With Quote
Old 12-27-2009, 12:53 AM   #12
hitec servos comes w/ good black plastic (thick) servo horn i been using to my rc8t ft & no problem (7955 strrng) ...................the horn got 4 holes so if you want more the 3rd or 4th holes is what youre looking for ........ IMO the alum. horn is not necessary
team terribles
mbx5rcr34 is offline   Reply With Quote
Old 12-27-2009, 09:20 AM   #13
BIG RE's Avatar
Trader Rating: 32 (100%+)
I know what picture you are talking about, it was the Hangar 9 horn, we used one on my race partners RC8T and it worked fine
BIG RE is offline   Reply With Quote
Old 12-27-2009, 09:36 AM   #14
Frank L's Avatar
I have bent several alum horns and I use the thick racers edge horns now they are made of a thick piece of alum no more bending horns. Plastic ones break, especially in a truggy.
Old 12-27-2009, 09:55 AM   #15
Integra's Avatar
I concur.....Ive bent many of older Racers edge and even a Non HD hanger 9 till Chad Bradley and Gary Guest showed me the CF trick....No more bent horns after that.
The new Racers Edge horns looks Uber Beefy and no chance at failing.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
