Old 12-27-2009, 04:23 PM   #16
merdith6's Avatar
Default When engines go...
I usually just get a new engine. It sucks to do, but it's not worth the parts to fix up an engine like that. I recommend a Novarossi .21BF for 150 dollars. It will last for a long time. the carbs are the best too. Nothing wobbles or leaks. good luck man....
merdith6 is offline   Reply With Quote
Old 12-27-2009, 04:24 PM   #17
smokinu's Avatar
Trader Rating: 60 (98%+)
Originally Posted by helivaguy View Post
you will see the rod slop more at TDC when rotating the crank back and forth,
agree you cant beat a novarossi carb.
btw the 14mm novarossi crank will work in there also.
the n21bf has the 14mm crank correct?
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 12-27-2009, 04:32 PM   #18
helivaguy's Avatar
Trader Rating: 42 (100%+)
yes so does the 21-4.
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 12-27-2009, 05:33 PM   #19
Cory Kerber's Avatar
Someone from my local track has a grenade he'll give me, so i may try that crank and see if it's any better. Here's the vid, not the best of quality, but you get the point.
http://s195.photobucket.com/albums/z...AYSTUFF023.flv
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 12-27-2009, 05:34 PM   #20
j_blaze14's Avatar
Trader Rating: 34 (100%+)
if it wasn't running hot then it was maybe too rich on the lsn, when orings go bad tuning is almost impossible. i did crack a couple cases before but temps went through the roof. i tried a nova carb before but noticed no defference in the motor other than now i hadf to learn how to tune a nova carb, i was so used to the go carbs already. flameouts are caused by way more than the motors rod/crank, fuel line, tank, clutch, mesh, etc.... what else have you checked?
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 12-27-2009, 05:39 PM   #21
smokinu's Avatar
i sold my grenade and parts to j blaze a couple months ago...
cory send it off to ray a and have it pinched.
Marcus P.
Old 12-27-2009, 05:54 PM   #22
I was planning on sending the p/s to Ray tomorrow. I just took a caliper to the crank pin and the lowest i got was 4.79mm and i got 4.97 right next to the big part of the crank. So i'm guessing 4.79 means it's shot.
I haven't really checked anything other than the engine.
*TEAM TERRIBLES*
Old 12-27-2009, 06:41 PM   #23
I think i may just get a Losi 350 engine. you can find them for less than $100 and they seem to be great mills from the thread on this site.
*TEAM TERRIBLES*
Old 12-27-2009, 06:52 PM   #24
smokinu's Avatar
look into the novarossi n21bf from houston aka H.E.S
he dose magic with this engine and can be had for a great price and well simply put its a novarossi.
Marcus P.
Old 12-27-2009, 07:11 PM   #25
I'm really not looking to spend alot right now Marcus. Especially since Dennis will sell me his Grenade cheap.
*TEAM TERRIBLES*
Old 12-27-2009, 07:15 PM   #26
smokinu's Avatar
Originally Posted by Cory Kerber View Post
I'm really not looking to spend alot right now Marcus. Especially since Dennis will give me his Grenade.
if you are going to continue to run the grenade look for a new go tech cooling head..
as thats were most the heat issues arise the head is so thick it cant accuretly cool the engine thats why they run 260-270 all the time.
Marcus P.
Old 12-27-2009, 08:05 PM   #27
Well guys, a local racer gave me a great deal on his 1 gallon old Grenade. So hopefully i'll start fresh with that engine and never look back. Thanks for all your interest/help.
*TEAM TERRIBLES*
Old 12-28-2009, 08:34 AM   #28
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
Default excessive
Yes, I would say (0.007") 0.018mm is excessive. I feel crank pin wear exceeding 0.003" Excessive/NO GOOD. I measure with blade mics .....seems to be best measuring tool measuring crank pins.
Glade you found replacement engine Corey
RayAracing
RayAracing piston+sleeve reconditioning-resizing Tooling+Services ALL Buggy, Truggy, Car, and Truck engine models .12 thru .50 since 2001
SHIPPING:4373 Creek Road, Chaffee, NY 14030 USA
PHONE: (716)783-5198 EMAIL: RayA@RayAracing.com SERVICE: http://www.rayaracing.com/
TOOLING: http://www.rayaracing.com/prodtooling.htm
RayA is offline   Reply With Quote
Old 12-28-2009, 08:57 AM   #29
HHHMMM will a p5x crank fit in a GO based engine? I think it is the 14mm crank but not certain.
matrixmike28 is offline   Reply With Quote
Old 12-28-2009, 09:35 AM   #30
helivaguy's Avatar
yes and yes.
Engine Cutting out When Applying Throttle MitchFX Nitro Off-Road 27 05-21-2009 05:41 AM
AXE ROSSI COBRA X1 EVO ENGINE deeph Nitro Off-Road 25 06-23-2008 07:26 AM
Engine Tech x_man Malaysian R/C Racers 745 11-27-2007 11:05 PM
