Old 12-26-2009, 12:01 PM   #1
Default Losi 8ight T won't start...Help!
Tank has 30% Odonnel nitro fuel. Flywheel matches up with starter box. When I push down on the glow starter, the flywheel engages and all of the wheels spin on the truck but it won't start. I took out the glow plug and it lights up bright orange in the glow starter. I also turned the car upside down with the plug out to see if I flooded it...nothing poured out. I pulled the fuel line from the engine and fuel poured out so I think it is getting fuel. I tried priming the engine by putting my finger over the muffler and that didn't help either. This is my first time starting a nitro car and I am out of ideas. Am I doing something wrong?
Thanks,
-Scott
ncstater6 is offline   Reply With Quote
Old 12-26-2009, 12:19 PM   #2
az00lude's Avatar
Thanks,
-Scott
I don't think the wheels are suppose to spin on the box unless something's wrong with your clutch like sticking.
take it to the track and have experience racer help you out.
Xray xb808
az00lude is offline   Reply With Quote
Old 12-26-2009, 12:28 PM   #3
Who8mySandwich's Avatar
Check your gear mesh.
Who8mySandwich is offline   Reply With Quote
Old 12-26-2009, 12:33 PM   #4
JBURCH's Avatar
If it didnt get flooded or priming didnt help either, make sure that the needles low speed or high speed are not closed, I had that problem come to find out I had closed the high speed needle and forgot, sounds like your not getting fuel.
JBURCH is offline   Reply With Quote
Old 12-26-2009, 12:53 PM   #5
I checked the needles and they didn't fix it. I also intentionally flooded the engine with a little fuel hoping to get a spark and it didn't help either.
Old 12-26-2009, 01:01 PM   #6
pickle311's Avatar
Trader Rating: 31 (100%+)
Is this a brand new motor?
pickle311 is offline   Reply With Quote
Old 12-26-2009, 01:05 PM   #7
JBURCH's Avatar
Try another glow plug, if that does not work post a pic maybe its something obvious fuel line on right lol. Got me stumped
Old 12-26-2009, 01:24 PM   #8
Eagle7's Avatar
Trader Rating: 25 (100%+)
turn the idle screw
MBX7T-Werks B5-2013. MBX7T Eco
MBX7r-Werks B6-2058 MBX7r Eco
TLR 22 2.0 & 22 2.0T
Werks Racing
Eagle7 is offline   Reply With Quote
Old 12-26-2009, 01:25 PM   #9
htcurt's Avatar
Thumbs up
i had same problem trying to start my new engine, it turned out the bottom end tuning screw was far from factory setting. Try messing with that a full turn at a time. thats all i did after a while and instantly started the car.
LOSI EIGHT 2.0 buggy + NOVAROSSI P5 XLT,
Novarossi 9901 Super Strong pipe & 41029 manifold.
Spektrum DX3s, SAVOX 20K-Steering,
ACE DS1015-Throttle/Brake.
htcurt is offline   Reply With Quote
Old 12-26-2009, 01:26 PM   #10
NochikenStrips's Avatar
Just how cold is it outside?
NochikenStrips is offline   Reply With Quote
Old 12-26-2009, 03:43 PM   #11
hdcruzer's Avatar
Turn in both needles till they just stop. Turn them out 2.5 turns. Take the aircleaner tube off the carb. Turn in the idle screw until you have about a 2.5 mil. gap. Get a blow drier heat the motor up to about 150 degrees and try again. If it starts let it idle through a tank. Put the A/C tube back on carb fire it up again. Idle should still be fast. Start turning in idle screw out until you get a nice idle. Go run figure 8s for about 3 tanks letting it cool down in between runs. On the 5th tank start fine tuning .
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 12-26-2009, 04:05 PM   #12
Joe Brinduse's Avatar
what starter box do you have??what way are the wheels going?
Joe Brinduse is offline   Reply With Quote
Old 12-26-2009, 04:38 PM   #13
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
This is just a few of my ideas im new to this also and i have had similar trouble. First I pre heat the motor with a heat to about 215 f-220 f Then open the carb up a lil bit with ur controler u may ned someone there to help if it finaly hits and starts to run kind of rev up and down a lil bit but not to much u do to much u might break ur con rod. If does hit then more then likely u need to open ur idle screw up a shade go in 1/12th to 1/8th turns at a time until it fires up.
Second if u fill that thats not the problem then try ur low speed needle [LSN] set back if not a factory settings and lean it out 1/12th to 1/8th at a time until it fires up before doing this again pre heat that motor with a heat gun.
Like a guy told me with these motors ur going to get aggravated and want to pull them out pound them in the ground throw them back in and doit again.
Another thing to if your wheels is turning when u got it on the starter box then ur clutch is ingauged and that means its going to put a resistance on your motor and not want to start. I myself this was my first mistake big big one I had the clutch all muffed up and when I did finaly get it started it screamed to the top all wheels turnned sound like I had a bad carb leak.You name it. So I why u was looking things over I go ahead and pull that bell off and take a look the bell should slip on and off easy real easy and if you do decided to take it of watch for the shims looks like lil washers be very careful and watch how you take it off be sure that all shims is acounted for sometimes they will stick on the inside of the bell next to your bearing so when you pull the bell off look on the inside of it there may or may not be a shim there also.
Good luck
kodiakbear7070 is offline   Reply With Quote
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi 8ight Truggy Flode007 Electric Off-Road 205 12-19-2006 12:32 AM
