Old 12-25-2009, 10:55 AM   #16
aaron joy's Avatar
Trader Rating: 16 (94%+)
You have to lock the axle. Stick something in between the "ears" of the yoke of the outer axle (closest to the wheel) and let us know what happens when you try to loosen the nut.
aaron joy is offline   Reply With Quote
Old 12-25-2009, 11:38 AM   #17
ScottyM's Avatar
Trader Rating: 27 (100%+)
Originally Posted by aaron joy View Post
It has to be one of three things wrong:
Hub is spinning in the wheel
Axle pin is broken
Axle is spinning inside the yoke
I had the highlted problem..
Originally Posted by Nitro F150 View Post
ok thanks. Wait so what should I do?
I used a pair of vise grips and clamped the axle and then was able to remove the nuts. Mine was on an XTM Xcellerator, but I was able to remove them.. I was starting to worry at first.
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 12-25-2009, 02:44 PM   #18
fukitol's Avatar
that track looks like a blast
is that fast, can i drive it, how much do they cost
fukitol is offline   Reply With Quote
Old 12-25-2009, 04:14 PM   #19
easyryder's Avatar
I like any track with dirt, on it
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 12-26-2009, 12:49 AM   #20
joehundy's Avatar
Trader Rating: 15 (94%+)
Default ....
not trying to be a butt.....but you need to dump the rustler if your gonna try to compete in gas truck just get the associated truck its so much better
joehundy is offline   Reply With Quote
Old 12-26-2009, 06:04 AM   #21
NDHotbodies's Avatar
are you turning the nuts in the right direction? not sure on your make, but some have right and left hand threads...
self sponsored, flat broke, highly sought after test dummy for Hotbodies..
I don't spell wrong, I just use shorthand sum time..
NDHotbodies is offline   Reply With Quote
Old 12-26-2009, 06:57 PM   #22
hambone's Avatar
Man i can't count the good times i've had at that track. Unfortunately it was made 1/8 scale unfriendly. Shame.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28963 07-28-2017 05:20 AM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 04:22 PM
Traction Compounds : Health Risks : what can we do about this? Martin Crisp Electric On-Road 785 06-11-2007 02:49 PM
