Old 12-24-2009, 11:49 AM   #1
Nitro F150's Avatar
Default How to get my back wheels off?
I just got new wheels and I got the front wheels off but I cant get the back wheels off.
Nitro F150 is offline   Reply With Quote
Old 12-24-2009, 11:54 AM   #2
NochikenStrips's Avatar
can you be more specific?
NochikenStrips is offline   Reply With Quote
Old 12-24-2009, 12:06 PM   #3
Nitro F150's Avatar
The bolt wont unscrew.
Old 12-24-2009, 12:15 PM   #4
BIG RE's Avatar
Trader Rating: 32 (100%+)
I don't know what car you have but as a general rule, if you can't get the nut to unscrew then either the wheel is stripped or you lost a roll pin. What you do in that situation is stick a flathead screwdriver in your outdrive to hold it stationary while you unscrew the nut, that should do it for you and then you can find the reason why it was not unscrewing in the first place.
BIG RE is offline   Reply With Quote
Old 12-24-2009, 12:17 PM   #5
Nitro F150's Avatar
I have a nitro rustler.
Old 12-24-2009, 12:38 PM   #6
You ncan also try to take a small pair of pliers or needle nose pliers and hold the driveshaft and unscrew the wheel nut. Once you get the wheel off, make sure there is a pin sticking through the axle where the hex snaps on.
cassidy is offline   Reply With Quote
Old 12-24-2009, 12:42 PM   #7
Nitro F150's Avatar
Ok can you please explain where is the driveshaft
Old 12-24-2009, 12:44 PM   #8
AndrewClaycomb's Avatar
It's the bar going from the differential to each wheel. When the car is rolling, the driveshaft spins.
Tekno 8ight
Kyosho Ultima SC
AndrewClaycomb is offline   Reply With Quote
Old 12-24-2009, 04:34 PM   #9
Ok can you please explain where is the differential
Old 12-24-2009, 05:00 PM   #10
I can see were this is going.
The Working Man is offline   Reply With Quote
Old 12-24-2009, 05:08 PM   #11
scwrod's Avatar
hehe
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 12-24-2009, 05:13 PM   #12
Frank L's Avatar
Trader Rating: 148 (100%+)
Personally I use a blowtorch or c4 and sometimes both.
It sounds like the nylox part came loose inside the nut. Needle nose pliers or little needle nose vice grips and tuen slowly.
Old 12-24-2009, 05:20 PM   #13
I can't help it. You need a bigger hammer. Sorry, I'll stop now.
Old 12-24-2009, 06:12 PM   #14
CanyonCarverR1's Avatar
There's a jerk in every bunch!
CanyonCarverR1 is offline   Reply With Quote
Old 12-24-2009, 07:59 PM   #15
sorry guys, had to do it.
How do you keep the dirt off? Jaz240 Nitro Off-Road 46 05-01-2009 04:15 PM
new to 1/8 racing, dont know how to setup my car murdermode Nitro Off-Road 12 03-30-2009 12:55 PM
The "How much is My Car worth thread" 1crazywhiteboy Electric Off-Road 28 08-16-2008 12:19 PM
