Old 12-24-2009, 08:52 AM   #1
Jaz240's Avatar
Trader Rating: 52 (100%+)
Default Run time on RX Lipo
Ok I am looking for some realistic Lipo Flat pack style ( same dimensions as 1500 NIMH) for the RX..Are you guys having no problems going 2 hours without charging?
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-24-2009, 08:56 AM   #2
Trey7's Avatar
If you are planning on running 2 hours without charging I would stick with the highe mah, say 2000 or better. I personally run the 2300 lipo and can run all my practice, 3 quals at 5 to 7 min, and the run my 30 to 45 min main with no problems. after the race I check my pack and it is still at 3.9 volts per cell.
Hobby Pro USA, Beta Tires, VP-PRO-USA, Werks Racing, Team Associated, Savox
Trey7 is offline   Reply With Quote
Old 12-24-2009, 10:25 AM   #3
Much More makes some 2400mah Flat Pack LiPo. I have 2500mah Hump Pack LiPo in my truggy, and I have no problem with battery-life. I only charge it before the main, but that is only to be sure. I am sure I could do the main as well on 1 charge.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 12-24-2009, 10:32 AM   #4
Jaz240's Avatar
My NIMH RX packs are getting old and I'm thinking of switching to lipos because I already have the HV servos. We run a 2 hour endurance race here at The Nitro Pit and its my favorite race of the year. I need to be able to get 2 hours on a single charge and have my pack not drained. It needs to fit in the Xray RX box, which takes the same size as the 1700 flat pack NIMH. So I am looking to see if its possible, If I cant get 2 hours safely I'll just get new NIMH
Old 12-24-2009, 10:47 AM   #5
Trey7's Avatar
I think you won't have a problem with a 2400 flat pack lipo. Just make sure it is freshly charged/balanced before you start the race.
Old 12-24-2009, 11:30 AM   #6
Integra's Avatar
X2 2400 should make it No question's asked.
Jaz ive ran my small 900's for 45min mains and it only take's roughly 600-650mah to peak back up...2hrs should be no problem.
Old 12-24-2009, 11:39 AM   #7
smokinu's Avatar
Trader Rating: 60 (98%+)
2200 mah and above should have no problem making 2 hours
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 12-24-2009, 01:11 PM   #8
Rampokker's Avatar
If you decide to stay with NIMH, team helotes have a 2600mah pack that fits in the xray battery box.
I was looking at lipos for my xrays a while back too and here are some protek lipos from amain.
2300mah & 2100mah
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 12-24-2009, 01:18 PM   #9
Jaz240's Avatar
and I can get 2 hours out of that?
Old 12-24-2009, 01:36 PM   #10
Rampokker's Avatar
I'm pretty confident that it would do it (Its also the biggest capacity one I've been able to find). Just depends on what your current draw is on your buggy. I would take the buggy to the track and with a full battery pack start running the car for around 30 mins (longer time will give better accuracy). Then charge the battery and see how many mah you put in. That should give you a good idea of what you'd need to get 2hr's of runtime.
Old 12-24-2009, 02:29 PM   #11
Jaz240's Avatar
Thanks for the links. I think I will do some more research. I want a clear answer that 2 hours is no problem and then I'll go Lipo..I dont want to buy the Helotes pack only to find out I cant make the 2 hours..From the replies of the other guys it seems 2 hours with the 2300 lipo pack should be no problem..I need to check those dimensions before I pull the plug
Old 12-24-2009, 02:39 PM   #12
Frank L's Avatar
Trader Rating: 148 (100%+)
I am running a losi 2000Mah pack and it lasts all day long. After a 30 min main it only seems to take approx 300-400 mah. I run one for practice and through the quals and then switch for the main. I would hate for it to go dead the last 2 mins, I think it has enough juice but why take the chance.
Old 12-24-2009, 04:49 PM   #13
Trey7's Avatar
Check this web site. they have deminsions for the batteries as well.
http://www.all-battery.com/74volt-23...pack39033.aspx
Old 12-24-2009, 05:14 PM   #14
Jaz240's Avatar
Thank you will do
Old 12-24-2009, 06:18 PM   #15
Trader Rating: 61 (100%+)
yeh i was gonna jump in here and say that running an xray buggy you may have fitment problems ..based on my buddies xray and his lipo delima and finding the right size ,,,,,,,there is NO way anyone can garantee a lipo will or wont run for 2 hours ..even in this day of high mah packs for rx's ...thats just my opinion especially running high zoot hv servos ...maybe you could run a regulator just for the 2 hour race ..not sure if that would help run time or not
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Tekin RS/RS PRO on 1s Lipo Q&A Randy_Pike Electric On-Road 1153 12-07-2016 08:18 AM
Is 2 hours possible? (Lipo receiver pack run time) portyansky Nitro Off-Road 23 10-10-2009 08:19 PM
ACE 1015 on unregulated lipo? WingWrecker Nitro Off-Road 35 09-21-2009 12:40 PM
